diyAudio Sponsor
Old 22nd July 2008, 11:01 PM   #2141
diyAudio Moderator Emeritus
Bas Horneman's Avatar
My new amp. SE 6N8S + 6P3S (triode mode).
Great looking amp. What output transformers are you using?
Old 22nd July 2008, 11:16 PM   #2142
Rodango is offline Rodango  United States
Rodango's Avatar
Send a message via AIM to Rodango Send a message via Yahoo to Rodango
Default Rodango Model DB-1 Bass Guitar Head
Here are some follow-up photos of my ultra rare Rodango Bass Guitar Amp. It is the only one in the world! It uses a 6SN7 preamp tube, a 6L6 for driving the splitter transformer and 4-KT88s in parallel push-pull. The power amp design was lifted from the Fender 300PS and the rest is my design and all of it is my construction. Custom made case, panel and plate.
Controls are gain and volume (front) hum and balance (rear) I have calculated its output at around 235 watts.
Old 23rd July 2008, 10:56 AM   #2143
alexg is online now alexg  Philippines
alexg's Avatar
I just built a phonostage based on: RJM 6dj8/6922
Here are the pictures of my RJM phonostage using 6n1p instead of 6dj8/6922:
On the left is my 12au7 VA/CF preamp, on the right (black chassis) is my RJM phonostage and below is my EL84 driven EL84 parafeed amp.
Old 23rd July 2008, 11:11 AM   #2144
Sander'Z's Avatar
I'm using transformers from old TV-set with mods. In plans change them, becuase this transformers so small to give me good sound. I hope you understand that I mean, excuse me for my english.
Old 23rd July 2008, 11:18 AM   #2145
O but small transformers can sound very good!
Old 23rd July 2008, 06:10 PM   #2146
FastEddy's Avatar
Default Re: Rodango Model DB-1 Bass Guitar Head
Originally posted by Rodango
Here are some follow-up photos of my ultra rare Rodango Bass Guitar Amp. ...
... Wondering if those high temp wire wound resistors cause any questions/problems? Is this usual or do many 'philes replace 'em?
Old 24th July 2008, 10:10 AM   #2147
sousmielie's Avatar
My small single valve ECL80 amp, work still in progress
It's one of the best feelings in the world when you build something without it going up in smoke............
Old 24th July 2008, 10:12 AM   #2148
sousmielie's Avatar
Only built this cause I was bored... Doesn't sound too bad, infact I think I've found a new PC speaker amp... :-)
Old 24th July 2008, 09:46 PM   #2149
bego2 is offline bego2  Croatia
nice. how much money did you spend on this amp? thanks.
Dance4Life
Tiesto4Life
Old 25th July 2008, 07:22 AM   #2150
sousmielie's Avatar
My amp, cost me about less than 13us $, or R85 SA.(not sure about exchange rate...)
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
vgeorge
Page generated in 0.13766 seconds (72.17% PHP - 27.83% MySQL) with 11 queries
