Please if is possible to say what is the objective for the list for Fairchild?
Best Regards
Group buy for absolute Mosfets that will be matched.
A preamp.
I can't believe I built this one. It looks good. Maybe I'm maturing.
EDIT *Oops, grainy pics. Definitely not mature enough to post decent pictures
Very nice,
What circuit/tubes did you use? Nice to see the wood. 🙂
M. Gregg
Very nice,
Hehe. Do you remember the Chinese chassis? It's gathering dust. 5692's in parallel -no CF.
Look like 6v6 brymar.
I will probably try the 6V6 Salas preamp on this chassis some day. It wouldn't take much time to modify the circuit.
Nice one, very clean!
Only the volume knob needs some serious thinking over... 😉
So all the inputs are live all the time or there is no volume control ??
Hidden maybe... Do tell...
It's a beautiful build, great job.
You gotta see it moving. Looks like I'm opening a safe.
Do tell...
A picture is worth a thousand words.
Thanks. Pure luck.
Quite elegant, can you post pictures of the inside? I really like it!I can't believe I built this one. It looks good. Maybe I'm maturing.
I will show the tube amp I told you I were about to build as soon as I get something 🙂
Hi regiregi, here's the inside before the remote control was installed. Yeah, pic sucks but probably better than nothing. Pretty simple as you can see. Circuit has 41 dB PSRR and CLC power supply - no regulator. I have the parts for the Salas regulator but I hate heat inside chassis so I keep postponing it, maybe for my next project - a headphone amplifier.
"Luciano" - 807 power amp
I picked up a couple of ceramic based ATS25/807s at a ham swap meet for $7 each. Recently I was given a pair of 807 which appeared in pristine condition. All tubes tested 85%. A volunteer on a another forum designed an Ultra-linear amp for me based on a 6SN7 driver tube a few years back. Finally the amp is finished.
The power and OPTs are Edcor, bases are Australian spotted gum and made by a local fellow amp builder. Tube bases and top caps ceramic, inter-stage caps Russian military. The top and bottom plates are 2mm Al and the colour "Red Delicious". It has a remote PS with currently 5Y3 rec. tube.
Though the power tubes are well used the rest of the components are new so I need 50 hours plus to burn-in. I have swapped the Sovtek for a Shuguang 50 year treasure. The amp appears to produce voice extremely well but I am still matching preamps and tubes to it.
OMG. Let me see....we have brown with red which is OK, but then we have the Edcor 'killer' blue and then everything goes down the toilet. My eyes, my eyes!
Yes you are right too many colours. It's not like me usually I get the colour balance right. In more subdued light the red looks like a reddy-brown and the Edcors darker blue.OMG. Let me see....we have brown with red which is OK, but then we have the Edcor 'killer' blue and then everything goes down the toilet. My eyes, my eyes!
6C33 monoblocs.
6SL7 input, 6V6 driver and 6C33 power tube.
Hammond mains transformers, Sowter plate choke and Edcor OPT.
Schematic:
JanE
Nice amp, and great schematic!
May I borrow your bootstrap idea? 😉
Psvane amp
Top valve in China
PSVANE: 300B-T X 2
Shuguang Treasure:6CA7-Z X 2
PSVANE: 12AX7-T X 2
Shuguang:5Z3PA × 2
Here ya go guys, a place to share pictures and a brief explanation of your favorite amp or latest project. For discussion or an in-depth writeup, let's post at the Discussion Thread. Hope this will suffice- Who's gonna start things off? (again)
Top valve in China
PSVANE: 300B-T X 2
PSVANE: 12AX7-T X 2
Shuguang:5Z3PA × 2
I have not tried these but are currently using TJ Full Music 300B SE carbon plate limited edition and 6SN7 50 Year treasure. I also have a a pair of Shuguang 300B-Z- very nice but in my Silver Dragon amp the TJs sound the best.Top valve in China
PSVANE: 300B-T X 2
PSVANE: 12AX7-T X 2
Shuguang:5Z3PA × 2
That 300B looks very similar to Chinese wases my parents bought in 1950'th, made from thin aluminium alloy, painted by gold on top of shiny black laquer. Nice.
Tubes will be the death of me. Psvane.Top valve in China
PSVANE: 300B-T X 2
PSVANE: 12AX7-T X 2
Shuguang:5Z3PA × 2
- Tubes / Valves
- Photo Gallery
