Photo Gallery
Photo Gallery
Old 23rd March 2008, 11:26 PM   #1951
flyinglemur is offline flyinglemur  Canada
So, the Irish can build stuff!!
That's the amp that inspired me
L
Old 24th March 2008, 01:54 AM   #1952
FastEddy is offline FastEddy  United States
FastEddy's Avatar
" ... So, the Irish can build stuff!! ..."
Not only that, but the Irish are the handsomest, friendliest, most musical and most talented of all the planets folk ... modest too.
Old 24th March 2008, 05:29 AM   #1953
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
The newest member to my family.
Old 24th March 2008, 11:15 AM   #1954
That's pretty!!
And re the irish, yup! that's the majority. except from this bizarre nouveau riche culture - driving 2008 Range Rovers, but diesel ones, "so ye can claim de VAT back". Lol - all show no go
L
Old 25th March 2008, 11:38 PM   #1955
Janez is offline Janez  Slovenia
My RH84 SE (not finished, housing is empty, OPTs need painting)
http://img142.imageshack.us/my.php?i...newamp2ri4.jpg
Old 27th March 2008, 12:59 AM   #1956
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
I *LIKE* this chassis repurposing! I'm going to need to stop by Halted (No. Cal. surplus place) and peruse the shelves for something wacky to build a tube amp into... Next project... or the one after...
Michael
Old 27th March 2008, 05:56 PM   #1957
New pictures:
http://img230.imageshack.us/my.php?i...mpfronttp2.jpg
http://img230.imageshack.us/my.php?image=ampbackdb3.jpg
http://img401.imageshack.us/my.php?i...pinsidehk7.jpg
It's almost finished now, next week I will replace some improvised resistors with new ones and close openings at back. PSU is separated but it's not finished yet.
Old 27th March 2008, 07:21 PM   #1958
FastEddy's Avatar
" ... I *LIKE* this chassis repurposing! ..."
Ditto that!
(I'm working up a sub woofer amp built into a tequila display box. )
Old 28th March 2008, 06:55 PM   #1959
basstard is offline basstard  Italy
basstard's Avatar
errrr,,, please excuse my ignorance but what's a tequila display box?
Old 28th March 2008, 08:39 PM   #1960
richwalters is offline richwalters
richwalters's Avatar
The Red sports car is illusionary but there are transformers around far bigger than that car.
Red Sports car performance for an amplifier ? Yup..This is a big and demon heavy amplifer to construct. No-one should attempt this size project without a physiotherapy and heart clinic nearby. Heavy handed- and high power electronic approach essential. Also assured 100% solder joint reliability. Stress bearing parts of the chassis uses airframe solid rivets for strength. There's alot to this practically completed over-winter project. Using point to point tag assembly this 250W+250W leviathan shown with new issue Tung-Sols 6550 comes in at iron-healthy 55kg (121Lbs)
These new issue tubes are excellent performers and upgrade others in their class and with amp derrated down to 450V B+; well matched parallel p-p pairs will easy tip 110W at 0.05% thd at 1Khz. (85mA Iq each) With a RS232 programmed PFC 1kW power supply, economic variable B+ performance is easily attained. All other internal supplies are stabilised.
Driver line up, 12BY7ís as balanced voltage driver triodes and ECF80 p sect as triode p/s.. simple.
Using KT88ís and 575VB+ the design goal is achieved with outputs exceeding 250W per channel extracted. (Strangely I got 650W in bridge mode, this seems high)
Although this is the last of the monster amps I shall build, the approach to amplifiers of this power class is somewhat different to lower powers as a considerable amount of detail, protective circuitry and larger earthing is required. The 4mm thick barbeque grill earth bus is very succesful.
Designed for longevity and a fantastic spec.. ANYone else on a monster project ?
richj
Photo GalleryHide this!Advertise here!
