SE 6S4S (6C4C) and PP 6P3S (6П3С)
This is my SE 6S4S (6C4C) and PP 6P3S (6П3С)
more Flickr: Oleg BEJAN's Photostream
Two stage tube phono preamp
Two stage tubecad tube preamp. Russian PIO inter-stage caps and Sprague RIAA comp.caps. Separate PS and preamp powered by 24VAC wall wart. Linear PS develops 295V. All built on veroboard no PCB. Excellent sounding. Also to use a MC cartridge I have built a Le Pacific jFET pre-pre.
Le Pacific pre-pre for MC
My build of the Le Pacific pre-pre was contained on a single piece of veroboard with battery pack. I matched the 2SK170 BLs. Output caps are Russian PIO. Same caps as use on the tubecad tube preamp in an earlier post. This pre-pre has been designed to work with the tube preamp which uses the same caps. It got cramped in the case but sounds excellent. Very pleased with both the Tube preamp and the Le Pacific pre-pre for MC.
Pretty standard EL-84 UL push-pull amp. I have used Russian tubes tubes throughout (6n1p and 6p14p-ev) running around 360V. I was tired of drilling aluminum plates, so I brushed off my junior high shop skills to bend some acrylic.
Nice, the smooth bends suit a tube amp nicely. Screams 50's. Very vintage looking!
Yes the rocket launcher gets them every time. That's a bread board KT120 with interchangeable driver section. It drivers a pair of KEF iQ30s.Mhouston,
I like the power(?) switch of your amp.
Posted Before
A 6BM8 Stereo SE amp I built.
Switchable triode/pentode mode.
Audio level indicator tubes.
Viewable in action at:
Tube Amp REV 2 Part 5 - Finished.wmv - YouTube
I enjoy listening to is almost as much as I enjoied building it!
Hey pilovis, I see you care for audiophile grade parts. Also, feeding that big tube with only 24V is going to make him angry - good for hard rock.
- Tubes / Valves
- Photo Gallery
