Old 8th April 2007, 10:22 PM   #1601
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Default Aikido Preamp
And an interior shot of the preamp enclosure:
File Type: jpg aikido preamp (full top view) 040807 (small).jpg (51.0 KB, 2761 views)
Old 8th April 2007, 11:30 PM   #1602
Default My attempt at an Aikido
I think it looks OK. My wife reckons that I should stain the pine a darker color? However, the camera has picked out scratches.
I am using diode rectified power. The rear tube is an Amperite 30 second delay. I have a separate 6.3VAC heater transformer, which is rectified and regulated using a Welborne Labs kit.
At some point, I'll upgrade to 12VDC and expermiment with 12V tubes.
Charlie
Old 9th April 2007, 07:47 PM   #1603
gertk is offline gertk  Netherlands
Smile My First EL84 PP
This my very first self built Tube Amp (actually I have built two of these since they are monoblocks)
It is based on a design in Radio Electronica from 1962
I replaced the power and output transformer by a set of Amplimo toroids (one inside the case and the other outside, stacked on a single M6 thread)
The tubes are 2 x EL84(of course) and an ECF83 as input stage and phase splitter.
All built into a Hammond cast aluminium box (quite small... I had to use some surgical handyness to get it all in...) the box runs quite hot though when it runs for a few hours :-( No chance i can close it up the way it was meant to be :-) (that's why its floating above the lid)
I planned to put 4 EL84 on the box since the output transformer is only 4 k anode-anode but the amplifier gets unstable with 4 tubes. Might be that the power transformer can't keep up but all voltages read quite OK. I also had a problem with the ECF83 generating some HF oscillation when driven with a large signal. For now I blocked it with a (too large) styroflex cap of 200 pf between anode and kathode.
Old 17th April 2007, 07:11 PM   #1604
rwellerson's Avatar
Hi all,
This is my most recent work: a trivial ultralinear amp, 60WRMS/channel.
Input tubes 6922 and power tubes 6550C (or KT88), continuously variable neg. feedback on front panel knob, overkill (almost...) output stage power suplly, independent input tubes power supply (cap/choke/cap), also separated for bias and for the input stage DC heaters.
3 steps manual power on sequence and HT standby switch.
Fixed bias and 0, 4 and 8 ohms speaker taps
All aluminum chassis and piano black hand buffed front panel.
Sounds very very natural and cristal clear.
[ ]s
Ricardo
Old 17th April 2007, 07:34 PM   #1605
rcavictim's Avatar
Nice job RW. I like the clean wiring inside.
Looks like you can check the output tube bias current from the top but you need to go inside to adjust it.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 17th April 2007, 07:53 PM   #1606
rwellerson's Avatar
Hi rca,
Thanks for your kind words.
No it is not that way: you can also reach the pots for bias adjustments from the top, they are (each one) just behind the bigger tubes but unfortunately the previous pics could not show them at all...
Ricardo
Old 18th April 2007, 06:23 AM   #1607
ddd is offline ddd  Bulgaria
BEAUTIFUL! Like all the works of rwellerson.
Old 18th April 2007, 12:10 PM   #1608
rwellerson's Avatar
Hi ddd,
Many thanks.
Ricardo
Old 18th April 2007, 03:11 PM   #1609
FastEddy's Avatar
I did not know it was possible to do such a beautiful job of point to point. I take it that those bus bars are lacquer coated transformer wire? .... Do you coat the inside of the chassis with this as well?
Also looks like plastic caps through out, except for those quality electro's on the power lines ...
Very neat, very tidy, better than factory work, a sight better than anything I have ever been able to do ...
Old 18th April 2007, 03:49 PM   #1610
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Ricardo;
nice work!
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Copyright ©1999-2013 diyAudio
