Old 29th December 2006, 10:02 PM   #1391
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I've finished this prototype yesterday, going to try it today on concert:
The prototype for this prorotype was Altec Lansing 1569A, I like their direct coupled phase splitter for the stability on low end when deep feedback is applied.
Mine uses 6p3s and 6n1p tubes. Initially I wanted 6n2p in input but gave up the idea because of stability issue on high end (too much gain). However, with different layout it would work fine.
Transformers are from ADA guitar amps. Measured maximal sinusoidal output on each channel is about 80 Watt.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 30th December 2006, 06:07 PM   #1392
Wavebourn's Avatar
It worked fine, I'm satisfied.
Old 30th December 2006, 09:06 PM   #1393
FastEddy's Avatar
Wavebourn: Noticing the multi-band EQ ... is that your "pre-amp"/ front end for this fine looking Amp ??
Old 31st December 2006, 04:00 AM   #1394
Wavebourn's Avatar
This thing sits between mixer pult and amp to equalize flat everything from microphones to speakers. It has "FBQ" feature, LED indicator on each band control, so when feedback causes oscillation on some frequency it is visible in which band this frequency is, so step by step frequency response can be corrected before the concert. On the picture FBQ is off so all LEDs are on.
Old 31st December 2006, 04:43 PM   #1395
FastEddy's Avatar
Wavebourn: " ... when feedback causes oscillation on some frequency it is visible in which band this frequency is, so step by step frequency response can be corrected before the concert. ..."
This is SOP for older stage hands, roadies ... ==>> A tried and true method and the best way to "equalize the venue" without resorting to lab quality equipment & measurements. Works best during final sound check with the crowd just beginning to fill the arena.
Old 31st December 2006, 10:45 PM   #1396
Wavebourn's Avatar
However, a crowd adds some damping factor, but anyway resonant frequencies almost stay the same.
Old 31st December 2006, 11:30 PM   #1397
FastEddy's Avatar
" ... a crowd adds some damping factor ..." and that's why you wait until some of the crowd shows up = to dampen the wall reflections, etc. ... Also, how do you make your live recordings? FW > laptop?
Old 31st December 2006, 11:55 PM   #1398
Wavebourn's Avatar
From analog pult to -> Tascam US-122->laptop
Sample: http://wavebourn.com/image/bohantsev/13.mp3
Old 1st January 2007, 12:44 AM   #1399
FastEddy's Avatar
" URL /image/bohantsev/13.mp3 was not found on this server. "
But thanks in any case.
Tascam equipment = pretty good for a USB device.
Old 1st January 2007, 12:48 AM   #1400
Wavebourn's Avatar
Sorry...
http://wavebourn.com/music/bohantsev/11.mp3
Happy New Year!
Copyright ©1999-2013 diyAudio
