#1371 |
Ok, so it's a EZ81 eq.
miklos |
#1372 |
Yes, a simple rec. tube that's easily available. Balance are 6V6GT and a pair of 6eu7. Again, cheap and easy to roll tubes. I have another version with 12AX7s and a choke. It is said to sound as good or much better.
#1373 |
Here's a picture of my wedding last summer....
#1374 |
Tubes are fore ever
best wishes , hoping that your WAF is as high as mine
#1375 |
OTL headphone amplifier based on two SRPP stages (E80CC and ECC99).
Max output level is 8.4V rms into 220 ohm. Distortion is 0.15% THD @ 1V rms. OTL: ![]() Schematic: ![]() Jan E Veiset
Life is hard - Then you die. |
#1376 |
Hi Jan,
Thank you for posting your latest project, I enjoy your circuits. Can you post the psu please and what is the value of the two resistors on the output? Many thanks, Phil. |
#1377 | |
Cheers, Shawn. BTW this feed from the DIY is one of the coolest things that ends up in my mail box. I love the "Art" that people pour into Valve designs. |
#1378 |
Here is what the power supply looked like on my drawing board. I did not follow the schematic 100%, the diodes (1N4004) that elevate the 7812 output voltage from 12V to 12.6V are left out and each 7812 feeds the filaments for one channel, etc.
OTL Power supply: ![]() The output serial resistors are 120 ohms. That will reduce the power into low impedance headsets but also increase the S/N. When using a 39 ohm load, max Vout is ~1.5Vrms, which is more than enough to drive low impedance, high efficient Grados, for example. A picture from the test bench: ![]() 1. e4 e6, your move ![]() Jan E Veiset
#1379 |
Hi Jane,
You're an artist!!!
Hello |
#1380 | |
BR, Jan E Veiset
