diyAudio Sponsor
Old 4th January 2004, 08:29 PM   #111
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Frank,
Yes the shellac is for a coherent soundstage and the olive oil for smooth highs!
Bas
Old 4th January 2004, 09:25 PM   #112
icebear is offline icebear  Norway
Default Mullard 5-20
Finaly it's working. Sweet sound.....
Old 4th January 2004, 09:27 PM   #113
Default Another one
More ligth.
Old 4th January 2004, 09:58 PM   #114
I could hear on them on arrival - believe it or not - was a local radio station.
I got a CD player has that problem! Each time I use headphone, I hear a radio station! I put a layer of aluminum foil inside the chassis and around the transfromer to improve the situation. It works!
C.C.
Old 5th January 2004, 09:16 AM   #115
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Nice work Icebear! Looks great.
Next you will be buying lots of NOS tubes for it
I take it those are EF86s and ECC83s at the front?
Old 5th January 2004, 06:02 PM   #116
Wink Yepp
That's rigth. Do you have any suggestions on tubes to try out?
Bjørn
Old 15th January 2004, 02:25 PM   #117
anannra is offline anannra  Canada
My GU-50/6DJ8 Single Ended amp... shot from top
Old 15th January 2004, 02:26 PM   #118
My GU-50/6DJ8 Single Ended amp... shot from side. and home brew cables to boot.
Anoop
Old 18th January 2004, 02:28 PM   #119
lagonda is offline lagonda  Taiwan
Default My EL-156
ECC-32 RC couples EL-156
Old 18th January 2004, 02:30 PM   #120
Default My 245
6SN7 interstage couples RCA 245 Globe
Page generated in 0.14308 seconds (62.46% PHP - 37.54% MySQL) with 11 queries
