#1091 | |
Thanks for the "stunning".... As I said just above the trafos are done under my specs and by a very good guy in this art. All of them oversized for their jobs. For ex.: the output ones we're done to stand 100WRMS each in this 60WRMS per channel amp. Believe me: bass is way much better (not more bass but lower and lower bass...) [ ] Ricardo |
#1092 |
MiniPP, EL84 power amp.
Distortion figures are quite good: less than 50dB (mainly 3rd harmonic -- higher order harmonic less than 70dB) at 5V rms output into 8-ohm resistive load. Onset of clipping is about 7V rms. Feedback mix: Local shunt feedback: ~8dB, loop feedback ~10dB. Zo is less than 1 ohm. ![]() Some tweaking/testing with different feedback fractions, idle current etc are still to be done. Latest schematic: ![]() Jan E Veiset NO-6600
Life is hard - Then you die. |
#1093 |
The 12AT7 is a great choice there (that's what I use in my EL84 amp). High mu, excellent linearity at the 10-15V swings needed for that circuit.
If there's a sucker born every minute, where do the rest of them come from? |
#1094 |
#1095 | |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1096 |
Thanks for the compliment choky
#1097 |
arnoldc, it's a matter of style. The wood is not a must in every design. I think this is a sample of nice and clever constraction!!!
choky is obviously a fan of the kitsch. Sorry, choky. |
#1098 |
Shishido style IITC 801A amp. PSU is a separate chassis.
#1099 | |
it isn't? how? http://choky.on.neobee.net/images/Choky's%20WOT.jpg ![]() now-that is not ugly....it's a mess
#1100 | |
