Photo Gallery
Photo Gallery
Old 6th June 2006, 07:24 PM   #1081
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by planet10
Those are the Frugel-Horn Mark 0 prototypes. Essentially a modified Buschhorn 1 with stock FE126e.
I've posted some more info (and a few Frugel-Horn Mk 1 pics on the LS Gallery pages.
http://www.diyaudio.com/forums/showt...388#post934388
dave
Thank's for posting that dave.. Altho i am un educated on these speakers i sure like them. .. Id like to use a tweeer on them tho.
Old 7th June 2006, 09:46 AM   #1082
gm70 is offline gm70  Viet Nam
Default se//
6L6//EL34 singed
Old 9th June 2006, 01:14 AM   #1083
jamesjung21 is offline jamesjung21  New Zealand
jamesjung21's Avatar
6L6//EL34 singed
Looks great
Did you mount sockets directly onto wood...?
Old 9th June 2006, 06:30 AM   #1084
Banned
So after many hours of listening and i mean listening i have decided to add a tweeter to this setup with a smal cap. ( cap came with the tweeter from my book shelf speakers i mod'ed a while back ) After doing this i am more happy to hear the upper high's and a little more happy i don't know what it is but i like a little bit of brightness to my speakers. Here is a pic to show you all. Also at this time im still running them with aleph mini's.. I have 4 chanels running, it is a little bit of a waste to have a separate 15watt channel dedicated to the tweeter but it sure sound's good.
Old 9th June 2006, 08:36 AM   #1085
ddd is offline ddd  Bulgaria
I'm sure it works. Because of the distance btw the two speakers you could try phase change of the tweeter.
Old 9th June 2006, 09:36 AM   #1086
rwellerson, perfect (as always)!
Old 9th June 2006, 07:27 PM   #1087
karma is offline karma  Canada
karma's Avatar
(little bit of a waste to have a separate 15watt channel dedicated to the tweeter but it sure sound's good.)
hay whatever works for you
http://www.karmaelectronics.org
Old 9th June 2006, 09:40 PM   #1088
Banned
The main reason for this is because they are all matched channels THEY all have closely matched part's. My bigger towers Love class a. I tried a gain clone well that lasted 20 min and then fired it back out the door.
Old 10th June 2006, 02:06 PM   #1089
karma's Avatar
how manny ohm's are your tower speakers?
Old 11th June 2006, 01:48 PM   #1090
rwellerson is offline rwellerson  Brazil
rwellerson's Avatar
Default Re: More
Originally posted by TomWaits
I really like old school using the new school together! I'm certain my valve amps will end up on PCBs. I like 6550 very much and I would like to know more about your circuitry, schematic? Did you machine the wood and steel, I bet you did. Could you bla bla bla some more, like where the circuit came from, transformers & valve mfgr's etc.
Very nice looking amp
Shawn.
Hi Shawn
Thanks for your kind words.
Well the circuitry is: 1st valve 6N1P input gain/phase inverter, 2nd 6BL7GTA phase splitter, with cathode compensation caps (very small values) for these two stages.
Output stage is a classic ultralinear type with 6550 (or KT88/90) with fixed bias.
As for the chassis this one is not steel: I use aluminum most of the time.
The side panels are machined from very noble and rare hardwood: the famous "pau Brasil" (yes with "s"...) (BTW this is the name of a native tree that gave its name to our country...)
Transformers: all of them made under my project and specs.
Tube brands: russian 6N1P, 6BL7 by GE and 6550C Svetlanas.
That's it.
Ricardo
Photo GalleryHide this!Advertise here!
