| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#1011 |
And I like them that way!
#1012 |
![]() What if I told you there was a special paint that would make the caps sound better???????????????????? |
#1013 |
Aside from shielding users from the potentials that may appear on the capacitor cans, the ugly plastic has a couple other advantages:
If you need to replace it, look at it and there the values are in plain text Some caps are wrapped in such a manner as to contain or direct a large leak / minor explosion so that they do not turn into little bombs
Jesus loves you. |
#1014 | |
Ah yes. I reccommend DC-3 paint since C-37 is a copyrighted magic sound improvement coating and costs too much.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#1015 |
Wall Candy brand white paint will help damp mechanical resonances reducing microphonics, and tasty too. Users agree, it improves psychoacoustic quality, Nero's fiddle sounds grandiose on systems so modified.
Be sure your foil hat has a good low impedance ground. |
#1016 |
Doesn't take much to get you guys started...
#1017 |
And we aren't talking about cables yet!!!
#1018 | |
#1019 | ||
Shawn. |
#1020 | |
Nothing to it, it is clean and the circuit leaves very little to the tube to color the stage. Great for a line stage that you require only a little gain from, from time to time. I wasn't looking for "warm" when I decided on building this. I must have studied and downloaded a thousand schematics and I'm not exagerating. I want sterile and clinical on a linestage perhaps you don't. Try it to see. I did it in a weekend including the case. Shawn. |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Powertrip, maxdd_nj |
| Page generated in 0.13709 seconds (72.76% PHP - 27.24% MySQL) with 11 queries |
