| diyAudio Sponsor | ||
| Thread Tools | Search this Thread |
#91 |
Hi all,
Here is my class A triode pre-amp. Tubes 2*12BH7A Golden Dragon and EZ-90 from Philips
LIM |
#92 |
This is a webcam type pic, so sorry about the sorry quality. I thought this amp would be a natural in a fireplace.....you get the heat, plus, with a mirror in back, even an orange glow
I've used this amp almost continuously since 1988, although I've rebuilt and upgraded the power supply - you wouldn't want to know how many corners I cut in the original version -for instance, I originally used a 1400VA toroid kit without winding any secondary, instead taking one of the primaries as a half wave rectified source for the output stages, but for the last ten years, it's got a 700VA toroid with proper homebrew secondaries for the sixteen output 6AS7G supply rails and their filaments. It's a fully balanced all triode design (except for the DC level shifters that use pentodes as current sources and as part of the output stage bias circuit, but the signal doesn't pass through them, so they 'don't' count This amp does respond down to DC, although I don't hate my speakers enough to not at least roll it off to unity gain down there. There is no servo offset control and no silicon devices anywhere in this amp except for supply rectifiers. Only negative feedback provides offset correction. I recently took it off the shelf where it had been sitting for two years & powered it up. One channel was sitting at 25mV dc and the other at about 100mV dc - hadn't been adjusted for at least four or five years & this with three fresh 6AS7G's (some had been mechanically damaged during storage) and snapped this pic after playing it for a few hours this evening. I think this amp probably still has more than half the original tubes in it
#93 |
Greetings
Jim |
#94 |
My first DIY 5687 preamp.
#95 |
12AU7 RCA x4, 6X4W GE, Jensen 1.0/630V out
#96 |
6SL7 Sylvania, 5881 Tung Sol, 211 United Electronic, OPT Tamura
18W/ch |
#97 |
6SN7 - 300B Billington Gold- 5R4 , 7W output
#98 |
Just finished mine after 6 months or so. PSE 300b based on Audio Note Conquest. Managed to underrate the PSU Tranny though, gets too hot after a couple of hours
The case is all fabricated 2mm ally, screw heads filled with bodyfiller and rubbed smooth. Sowter Iron. All done on the kitchen worktop |
#99 |
Tube complet : 5692 RCA red base, 6SN7 Sylvania 1950, 300B EH
OPT Hi-Fi National (Japan) very cheap! 6W/ ch |
#100 |
300B stereo
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| jacobthellamer, vconsumer |
| Page generated in 0.11395 seconds (67.04% PHP - 32.96% MySQL) with 11 queries |
