| diyAudio Sponsor | ||
Ok, I am seriously needing a model for a 7591. I am barely proficient at LtSpice, and a long ways from being able to do my own models yet. I have tried a couple of tube modeling programs that members here have written…but I stink up the place, and haven’t had any success.
It would be really swell if one of the spice Uber-User’s here could spend a little time and produce one…please…pretty please. Since the 7591 is back in production, and a lot of vintage gear run ‘em, I am positive that I’m not the only one that could use this model…think of the fame…think of the adoring adulation’s…think of ME! Did I say please? Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#2 |
Hello Casey :
Your pleading has touched me to my very heart. I can feel your pain. So since I am in a generous mood today, I decided to work up a model for you. But I found that none of the spec sheets I could find for 7591 give plate curves. This may explain the lack of published models for 7591. But surely there must be plate curves somewhere for 7591. I do not have any 7591 personally, so I can't measure the data myself. (which I prefer to do rather than using spec sheets anyway) You mention that you have tried modeling unsuccessfully, do you mean for 7591 specifically, and if so do you have 7591 data ?
Robert McLean |
#3 |
Heres the Pentode curves.
#4 |
Heres the triode connected curves.
#5 | |
I can't thank you enough for the effort. Casey
#6 |
Casey :
Try this model. Its not the greatest fit below 50 volts, but it is not bad for the limited data available. The shape of the plate curves looks a bit funny below 50 volts, but curves I ran in triode mode look pretty good. Use at your own risk, no guarantees and all that stuff. **** * * R McLean 9 January 2005 * * 7591 pentode * parameter extraction, from data sheets, 9 January 2005 * grid current not modeled **** * .SUBCKT 7591 A S G K + PARAMS: Ex=1.3215754205161 Kg1=972.600855246932 Kp=97.9392597291279 Kvb=25.0367202802361 Mu=16.7208998295801 + Exd=2.78742077218546 Kd=159498.449500327 Ks=1.89047582270854 Kg=0.00189539610643784 + CCG=10.0P CPG1=0.25P CCP=5.0P Eat at 0 Value={limit(0.636*ATAN(limit(V(A,K),0,2000)/KVB),0,1)} ; arctangent shaping Eme me 0 VALUE={PWR(LIMIT(V(A,K),0,2000),EXD)/KD} ; diode line Egs gs 0 VALUE= {V(S,K)/KP*LOG(1+EXP((1/MU+V(G,K)/V(S,K))*KP))} ; effective voltage Egs2 gs2 0 VALUE={(PWR(V(gs),EX)+PWRS(V(gs),EX))/(KG1*0.636)} ; total space current G1 A K VALUE={LIMIT(V(gs2)*V(at),0,V(me))} ; plate current Escrn sc 0 VALUE={KS*V(gs2)*(1.1-V(at))} ; reverse arctan shaping for screen current G2 S K VALUE={Limit(V(sc),0,10)*LIMIT(V(S,K),0,10)/10} ; screen current * no grid current data available so comment out the grid current line *G3 G K VALUE={PWR(LIMIT(V(G,K)+1,0,1E6),1.5)*(1.25-V(at))*KG} ; grid current C1 G K {CCG} ; CATHODE-GRID 1 C2 A G {CPG1} ; GRID 1-PLATE C3 A K {CCP} ; CATHODE-PLATE .ENDS 7591
Robert McLean |
#7 |
After I posted my last message I saw that the lines were not wrapping properly, ie my cut and paste did not work quite right. You could fix it manually, but thats a pain, so here is the model uploaded as a text file.
Robert McLean |
#8 | |
THANK YOU MR. McLEAN !!!
I will model my Fisher's output stage this evening, and report back. Quote:
I'm sure it's good enough to show the relative performance differences of different splitter/driver schemes I'm considering.You may want to check the date on your file Is it ok to share this model, as long as I leave your info on it ? I suspect others would be interested in it. Thanx again Robert...you 'da man!! Casey
#9 | ||
Robert McLean |
#10 | |
Just a quick note to say that I successfully simulated my Fisher 800C's power amp using this model in LtSpice...thanx again Robert, and to everyone else this model works . Casey
| Help With 6v6 Spice Model | porcatroya | Tubes / Valves | 0 | 5th May 2008 06:41 AM |
| lamp spice model | radtech | Parts | 2 | 11th March 2007 10:19 PM |
| SPICE model | Prune | Parts | 6 | 16th October 2004 03:22 PM |
| Spice model | doigtee | Tubes / Valves | 6 | 12th July 2003 11:42 AM |
| Spice model for LED? | G | Solid State | 5 | 14th September 2002 03:33 AM |
| Page generated in 0.12072 seconds (80.09% PHP - 19.91% MySQL) with 11 queries |
