| diyAudio Sponsor | ||
#11 |
I have a few 2400 uF 450 volt beer cans that I got on E-bay. Reforming is simple if you have a variable power supply. Hook the cap up to the power supply, set it at about 50 volts, and leave it for an hour or so. After that turn the voltage up 50 volts and wait about 15 minutes. Each 15 minutes raise the voltage 50 volts until 400 or so is reached. KEEP AN EYE ON THE CURRENT METER. It is normal for the cap to draw current as the voltage is raised. The current should drop to a few mA or less after a few seconds. Any cap that draws continuous current or gets warm should be discarded.
----------SAFETY WARNING--------- As explained before there is a lot of energy storage available here. This is of value in some amp designs. It is VERY DANGEROUS if abused. I would put the cap inside a heavy cardboard box during the reforming process. A cap that suddenly shorts internally can violently explode, or spew its electrolyte through the vent. Discard any leaky caps (those that get warm or draw current), these are prone to sudden failure. The electrical energy stored within can cause a serious shock, and WILL vaporize a small screwdriver if shorted out. The current pulse generated by shorting out one of these will usually cause damage to the cap, and any thing else in the path. BE CAREFUL. Discharge these through a large resistor, and verify that there is no residual voltage (with a voltmeter) before handling them. Now what can you do with these. They are useful as a "stiffening cap" across the power supply in a class AB power amp. These make a noticible improvement in the bass and transient response in some amps. The initial charging current is outrageous and the power supply must be able to supply it without damage. I had one of them in my 300Beast amplifier. the charging current was limited by using an "inrush current limiter" in the transformer primary. The large cap actually slowed the turn on of the entire amplifier by several seconds. I have since removed the beer can and replaced it with a 470uF 450volt PC board cap with similar results. Size was the reason. I plan to use the caps in a series (with equalizing resistors) connection for the filter in a high voltage power supply for my 833A amp. They would be useful in the power supply of an OTL amplifier (as suggested) because the peak currents here are in the multi amp range. These caps usually have lots of internal inductance and therefore exhibit lousy behavior in the upper audio range. For best performance they should be bypassed with a good cap. I use surplus oil caps, or Solen fast caps (or both).
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#12 |
The caps are 3 months old. I have a friend who likes to experiment with high voltage combined with high current (coin shrinking) who ordered a case, as it was the cheapest way to get the amount he wanted, and he gave me the 4 extras (nice friend).
Currently the leakage current is under the 5 ma rating from the manufacturer. I'm planning on making a pair of PPP EL34 amps so I can finally use some of my stash of tubes I've built up over the years. I guess I'll go with some smaller ones, and save myself some headaches. |
#13 |
Please reform caps with a current limiting resistor, then the voltage increase is automatic and the chances of venting or "explosion" are nearly gone. This is what the manufactures recommend. Also note that you should reform to the surge voltage not just the rated voltage.
There is some interesting information on reforming electrolytic caps at the end of this page: http://www.duracap.com/electrolytic_...tion_guide.htm |
#14 |
I agree that a series resistor should be used to limit the current, but that will not help reduce the risk of explosion if a cap internally shorts. The stored energy inside the cap is more than enough to rupture the can. I have seen it happen, and it wasn't pretty.
#15 |
my setup for capacitor reforming, caps shown are for ss amp but provedure is the same for higher voltage caps. i used a supply voltage equal or greater than by 1.5 x printed wvdc on the caps.
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
| Rebuilding a DAC Audio grade or Computer grade caps? | gto127 | Digital Source | 0 | 28th January 2009 09:17 PM |
| Computer Grade/Inverter Grade Cap | TunaFish | Parts | 2 | 11th March 2005 03:51 PM |
| Computer Grade Cap or Inverter Grade Cap??? | TunaFish | Tubes / Valves | 10 | 11th March 2005 08:48 AM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 02:29 AM |
| Computer Grade Capacitor?? | ghee0 | Solid State | 5 | 24th January 2002 10:59 AM |
| Page generated in 0.10353 seconds (74.69% PHP - 25.31% MySQL) with 10 queries |
