diyAudio Sponsor
Old 4th January 2006, 10:27 AM   #1
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
Default 12 volt preamp
Hi guys,
I got this cute miniature 6ag5 tub from a friend i traded with.
googling for an application i came across a radio citcuit using it in a 12 volt application.
Just out of curioity i powered up mu 12 V dektop supply and plugged some resistors 'n caps in my breadboard.
Within a short time i was hearing audio, after a bit tinkereing i am hearing GOOD audio.
Looks all cool on the scope. Don't know how to measure distortion, but it sounds teriffic.
Now i am suspecting there is some drawback, else we would all hook tubes to low voltage supplies.
Could anybody enlighten me why this isn't done more?
I am thinking: 12 lead acid battery and make a hummless phono!
Old 4th January 2006, 10:36 AM   #2
This IS being done and is already a very famous approach in the headphone amplifier scene. The most notable implementation mates it with a buffer output and is called the Millet Hybrid Amplifier.
Old 4th January 2006, 01:51 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
12 Volt is maybe to overdo it.
But there are a few tubes that do reasonably well at lower voltages.
Say between 50-100 Volt.
But some values of performance will not be optimal.
What will suffer I do not know, as I am no tube expert.
One tube that can run a bit lower (than 200 Volt) is 6DJ8/E88CC/6922.
Here is a thread about same topic:
Running tubes at lower voltages
lineup
Old 4th January 2006, 03:12 PM   #4
owen is offline owen  United Kingdom
Nope, these are tubes designed for 12V operation - typically for car radios!
Thought about finding some, but in the end I have too many other things to do!
Owen
Old 4th January 2006, 03:27 PM   #5
beamnet's Avatar
which tubes?
Bas
Old 4th January 2006, 05:04 PM   #6
For 12v single triodes we have the 12AE6A, 12FK6, and 12FM6.
These are all designed for car operation and can thus run well off a 12v SLA.
Old 4th January 2006, 05:16 PM   #7
The 6GM8/ECC86 is a LOW voltage relative of the 6922. It's a fine Dutch product.
Eli D.
Old 4th January 2006, 10:21 PM   #8
316a is offline 316a  England
316a's Avatar
Hi ,
I don't know about the space charge valves mentioned earlier but the ECC86 looks like a safe bet . Otherwise if you can stretch to 50v or so , miniatures such as 3S4 are a possibility and there are many subminiature types that run at low voltages . Steve Bench has a battery phono stage on his site , maybe a good reference ?
cheers
316a
Old 5th January 2006, 04:10 AM   #9
rcavictim's Avatar
I have a bunch of NIB 12CN5 and was thinking of a battery amp myself. These are IF pentode but ought to work at lower frequencies I'd think. You can actuallly get 4.5 mA plate current happening with 12 volts B+. Here's data on this baby. http://www.nj7p.org/Tube1.php?tube=12cn5
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 5th January 2006, 04:19 AM   #10
lineup's Avatar
6GM8 is tube design especially for 12 volt supply ( in car battery operation ).
At plate 12 Volt will run like 2.5 mA
At plate 6 Volt will run like 0.8-1.0 mA
I guess that when plate 6 Volt, the supply is 12 Volt
and anode resistor is like 5 kOhm
and cathode resistor 1 kOhm
Heater is 6.3 Volt / 330mA
lineup
120 Volt psu PreAmp - lowest possible G-FeedBack lineup Solid State 68 18th January 2009 08:57 PM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
Volt in a TL BlackCatSound Multi-Way 24 1st November 2004 07:29 AM
9 volt powered pocket mic preamp circuit example grovel darren01 Chip Amps 0 5th March 2004 10:05 PM
12 volt tube preamp help blackreplica Tubes / Valves 5 23rd December 2003 09:56 PM
Page generated in 0.09110 seconds (83.75% PHP - 16.25% MySQL) with 10 queries
