diyAudio Sponsor
Old 3rd January 2006, 12:38 AM   #1
XZur is offline XZur  Philippines
Thumbs up PSU Question
What's the trick to sqeeze 500v of B+ from a trafo with secondary 300-0-300v? Un-Possible
Old 3rd January 2006, 12:52 AM   #2
Tie the center tap off. Use a hybrid bridge of 2X UF4007s and a 5AR4. Use choke I/P filtration. The B+ will be slightly above 500 V.
BTW, a "proper" choke I/P filter is LCLC.
Eli D.
Old 3rd January 2006, 08:47 AM   #3
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Eli,
will the mA rating will affected? Can I squeeze out the same current or am I wrong? In theory your'e increasing voltage at the expense of avabile current...
Old 3rd January 2006, 10:01 AM   #4
Giaime,
You're absolute correct about TANSTAFFL applying. A rectifier winding is rated for some number of VA and that number is NOT to be exceeded.
The saving grace in the situation is the fact that when choke I/P filtration is employed, the full RMS current capability of the rectifier winding is available as DC. When cap. I/P filtration is employed, approx. 1/2 of the max. AC RMS current is available as DC.
Choke I/P filters are voltage poor and current rich. Cap. I/P filters are voltage rich and current poor.
Eli D.
Old 3rd January 2006, 11:03 AM   #5
Giaime's Avatar
Yes, thanks, I understand.
But with bridge rect. and choke I/P, will I have more current avabile than full wave rect. and cap I/P or it will be the same, only the voltage will be different?
I ask this because I'm making plans for a tube power amp, and I'm restricted with a salvaged 300-0-300 transformer, so I can't decide if I can go to SE of big tubes (aka 6L6GC, 6550, KT88) or PP of small ones (6BQ5, 6MB8, 6V6 etc etc...)
Old 3rd January 2006, 01:59 PM   #6
Tweeker is offline Tweeker  United States
Choke input will allow similar wattage as cap, if not somewhat more. The high current peaks are mitigated. So yes, more current, lower voltage.
Edit- this post assumed the same rectification in both cases (bridge).
Be sure your foil hat has a good low impedance ground.
Old 3rd January 2006, 02:09 PM   #7
Tom Bavis's Avatar
You can get more DC watts with a full-wave bridge than a 2-dode full-wave, for the same AC VA. Think of it this way...all the copper is carrying current on both halves of the AC, not just one half.
You can estimate the AC current capacity from the winding resistance. For a big transformer, 3 watts of heating in that winding will be ok. So max current is sqrt(3/R). You can use PSU Designer from duncanamps.com to model the RMS current with a given DC current draw.
High voltage is NOT good for single-ended operation - class A usually is best at a lower voltage. at 500-600V, EL34 and 6550 are not in a very linear region - better for class AB push-pull.
Old 3rd January 2006, 03:39 PM   #8
Giaime's Avatar
Hi Tom,
so I assume it's better to use that PT for an EL84PP, like the amp where it comes from.
Thank you very much
Old 4th January 2006, 01:18 PM   #9
Thank you all for the inputs.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10907 seconds (76.27% PHP - 23.73% MySQL) with 10 queries
