diyAudio Sponsor
Old 25th October 2002, 12:37 PM   #1
G is offline G  United States
G's Avatar
Default Do I have this CCS configured correctly? Tube preamp..
Hi Guys,
While I'm waiting for parts to build a Zen V4 I thought that I would throw together a preamp circuit to drive it. I believe that I have all of the calculations correct. Any opinions or advice are appreciated.
G
Gavin
Old 25th October 2002, 01:28 PM   #2
HDTVman is offline HDTVman  United States
Gavin
Not even close.
1. As drawn you need a PNP transistor and reverse the Emitter/collector connection and use only one stage (one transistor, LED, resistor).
2. I would connect the bias resistor to the plate/collector connection. (Lowers the wattage requirement).
The way the stage is drawn the transistors are reverse biased. With the stages stacked the way they are the bias for the transistor connected to the tube plate will keep it turned off.
I think you should go take a look at the current sources used in the Pass amplifers again.
Later
Bruce
What ever makes the tunes flow
Old 25th October 2002, 01:33 PM   #3
Joel is offline Joel  United States
Joel's Avatar
Default new to me...
Gavin,
I'm new to solid state design - what is the purpose of all the circuitry in the plate circuit of the 6SN7?
Also, where is the gain control? I didn't see one.
joel
Old 25th October 2002, 02:27 PM   #4
Brett's Avatar
G,
Learn from a <a href="http://home.pacifier.com/~gpimm/">master</a>. Especially take note of <a href="http://home.pacifier.com/~gpimm/45_all_active.gif">this one</a> as it's similar to what you're trying to do.
Gary's BBMCCS will be the load for the driver stage in my 813PP monster.
Joel,
The purpose of the CCS is to replace the normal anode loads of resistor, choke or IT primary with the highest possible impedance broadband load. It maximises the linearity of the tube (if well implemented) and usually gives the circuit a bit more gain (gain=u). It also stabilises the operating point of the tube. The loadline will be near horizontal.
Old 25th October 2002, 02:59 PM   #5
G's Avatar
Hi Brett,
If you look at the gain stage of the diagram that you posted I've done the same thing as Gary did. The only difference being that I biased the LED's separately and added the bypass caps. It's merely a fancier C4S.
G
Gavin
Old 25th October 2002, 03:02 PM   #6
Joel's Avatar
Default I see...
Thanks for the reply Brett!
I thought the "linearity" of the tube (Transfer Characteristic) was inherent to the tube regardless of load/type of load/etc?... if not, how are they are able to draw plate curves?
Also, doesn't a fixed bias supply set, and hold, the operating point - regardless of external conditions? Hence the term "fixed"?
Sorry if I'm pestering! Just trying to figure this circuit out.
joel
Old 25th October 2002, 03:18 PM   #7
steve jones's Avatar
Originally posted by G
Hi Brett,
G
The BBMCCS that Brett referenced (but not linked) is not a C4S variant. Take at a look at:
http://home.pacifier.com/~gpimm/Battery_biased_ccs.htm
I've been around Gary since his push-pull tube days. He originally started using a C4S as a CCS plate load on line level tube circuits. He got the itch to size it up for the SE 45 amp linked above. Later, he used a pentode as a HV ballast and isolated the SS current sensing portion of the curcuit. He's since come up with a number of versions (note: 2 connection CCSes), the battery bias mosfet constant current source (BBMCCS) being the latest.
The original C4s has around a -40dB noise figure. The BBMCCS measures better than -115dB to 1kHz. As Linda Richman would say: "It sounds like butter".
FWIW, Gary is an engineer at Tektronix and IMHO, a freaking brainiac.
Try the BBMCCS, G. It'll do you good.
Steve
Old 25th October 2002, 03:51 PM   #8
G's Avatar
Thanks very much Steve. Minus 115 dB sound very nice.
G
Gavin
Old 25th October 2002, 04:40 PM   #9
G's Avatar
How does Gary keep the batteries Charged? Replacing them everytime they go dead will be a pain. Or are they used merely for potential at the gates with little if no current flow?
G
Gavin
Old 25th October 2002, 04:41 PM   #10
diyAudio Senior Member
fdegrove's Avatar
Hi Gavin,
Correct,there's hardly any current drain.
Frank
FA: Eico HF-85 Tube Preamp &amp; HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 07:14 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Am I using UniBox correctly? needtubes Subwoofers 3 12th June 2005 02:02 AM
Page generated in 0.11559 seconds (78.24% PHP - 21.76% MySQL) with 11 queries
