What I have: 4 Tubes. What I need...
Old 31st December 2005, 03:26 PM   #1
pixpop is offline pixpop  United States
pixpop's Avatar
Default What I have: 4 Tubes. What I need...
Through a mistake I made in ordering some replacement tubes for my HP 200CD Oscillator, I now have these 4 homeless NOS tubes:
2x 6SH7 (Branded KEN-RAD)
2x 6AU5 GT (Branded RCA)
I have the following projects on my list of things to do, and wondered if any of these tubes are good choices for any of these projects:
An RIAA preamp for MM cartridges.
A line stage
A 2 way active filter for bi-amping
Thanks,
Neil
Old 31st December 2005, 05:29 PM   #2
Eli Duttman is offline Eli Duttman  United States
Neil,
The 6AU5 data sheet suggests suitability in voltage regulator service. Regulated B+ definitely has its place in preamps, particularly phono sections.
With DC on the heater, the 6SH7 might make a good 2nd gain block in a passively equalized phono preamp. Perhaps 6922 sections in the 1st gain positions. Be sure to buffer the line level O/Ps. 5687 or ECC99 cathode followers seem about right, but JFETs could work out too.
Eli D.
Old 31st December 2005, 07:40 PM   #3
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
The 6AU5 can be used as an output tube, but the screen voltage needs to be lower than the plate - perhaps regulated? The 6SH7 is a linear pentode, good for a gain stage. Mu about 35 triode connected. GE data sheet says "not recommended for high gain audio amplifier due to hum." I'm sure it would be fine at line levels.
I take it your 200CD is the later one with 6AU6 and 6CW5?
Old 31st December 2005, 08:06 PM   #4
pixpop's Avatar
I'd have to open it up again to be sure, but what I can say is that these tubes dont fit. The tubes in the oscillator are more miniature, with finer pins, and these replacements don't fit. I later found out that the oscillator didn't need new tubes anyway. I just had to fix a problem with the attenuator and now it works fine.
It's a beautiful thing, and also acts as a ballast to keep my bench stable during earthquakes ;-)
But it sounds as though, if I want to build a phono stage, I'd be better off choosing some other tube. That's OK.
What I have: 4 Tubes. What I need...Hide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 06:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
Copyright ©1999-2017 diyAudio
