| diyAudio Sponsor | ||
I have Heathkit AA 151.
1. What is AF amp circuit? (6AU6 and 6AN8A) What is XTAL (Crystal) Phono in input section? 2. I've found that it has EQ and ST<->Mono Circuit. Do you think it is worth of keeping them? Well, I like pure signal path better. 3. If not worth, how can I eliminate them? How about just bypassing 6AU6 and 6AN8A (so-called AF Amp circuit) and adding some Rl between them? Thanks. |
#2 |
I ran a Google search to find a schematic. It turns out that the AA-151 is the same as the SA2, except for 6EU7s instead of 12AX7s.
If you examine the linked schematic, you will see that the 6AN8 forms the voltage gain and phase splitter stages of the power amp section. You can't bypass the 6AN8. What are your objectives? What sources do you use?
Eli D. |
#3 |
original schematic. (Sorry, I forgot to attach it.)
http://mcnally.cc/pics/aa151l.jpg http://mcnally.cc/pics/aa151r.jpg http://mcnally.cc/amps.htm Well, 6AN8 works for both "AF AMP" My question is 1. what is "AF AMP"? "AF AMP" looks like a circuit of EQ and Mono-Stereo SW to me. 6AU6 and 6AN8 (pentode part) seem to work for "AF AMP". If it is not important, I want to eliminate it. 2. However, Signal goes through 6EU7 -> 6AU6 ->6AN8...... Is it too much gain? |
#4 |
The 6AN8 is critical to the operation of the EL84 "finals". You can't get rid of it unless you do a complete redesign.
If a CDP is your only source, you can bypass everything in front of the 6AN8s. Wire the I/P RCA jacks to 10 KOhm volume controls. Connect the wipers of the pots. via 68 nF./63 WVDC caps to the 6AN8 pentode control grids. Connect the control grids to ground via 100 KOhm/1% metal film resistors.
Eli D. |
#5 |
Xtal phono is for high-output cartridges, rarely seen these days, made from piezoelectric crystals. They were most common in VERY cheap phono systems back in the '50s and '60s.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Hi zxx123
Disconnect the cathodes of V4/5 from the cathodes o V9/10. And use a cathode resistor of 200 Ohms bypassed with a electrolytic capacitor , for each pair of output tubes V 4/5 and V9/10. That way you minimise the low frequency cross talk that ruins the stereo image.
Jorge |
#7 | |
Please provide a list of all the sources you intend to use with the AA-151. Incomplete info. makes providing reasonable recommendations VERY difficult. If you plan on using a turntable, the phono section needs (IMO) to be reworked. Super low hum or not (6EU7), AC on phono section heaters is FUGLY.
Eli D. |
#8 | |
However, is only 6AN8 enough to drive EL84? Moreover, NFB circuit of 6AN8's cathode may reduce the gain. How about going from 6EU7 to 6AN8 (triode part for PI). |
#9 | |||
The 68 nF. cap. connecting the pot. to the 6AN8 forms a filter in combination with the 100 KOhm grid leak resistor that keeps low freq. crud out of the amp. That, in turn, allows the value of the coupling caps. between the splitter and "finals" to be increased to 100 nF. The result is tighter, less tubby, bass as the low freq. error correction signal present in the O/P trafo is reduced. There's less phase shift inside the NFB loop too. 716P series Orange Drops are perfect for the replacement coupling caps. Another sure fire tweak is to use separate bias networks for each pair of finals. Getting TIGHTLY matched pairs of tubes is tough enough. TIGHTLY matched quads are much more difficult to obtain than TIGHTLY matched pairs. Use 200 Ohm/5 W. resistors and 150 muF. 'lytics in the new bias networks. BTW, how does the AA-151 handle the power on/off function?
Eli D. |
#10 | |
Thanks. I will keep them.
It is just a normal power sw. See M5. |
| Was There a Heathkit W-1M or WM? | PB2 | Tubes / Valves | 12 | 20th May 2009 12:42 PM |
| Heathkit aa-121 | maritimer | Tubes / Valves | 4 | 16th July 2008 03:45 PM |
| Heathkit AA-100 | imix500 | Tubes / Valves | 2 | 28th December 2005 09:35 PM |
| Heathkit TT-1A | lpd | Swap Meet | 0 | 21st November 2003 05:01 AM |
| Heathkit EA-2 | Hewie | Tubes / Valves | 6 | 14th October 2003 06:41 PM |
| Page generated in 0.12880 seconds (83.01% PHP - 16.99% MySQL) with 11 queries |
