diyAudio Sponsor
Old 30th December 2005, 11:09 AM   #1
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Default Motorrun caps ... GND side?
Folks,
I just received a box full of oil filled caps ASC 100uF/370VAC. I need them for my next amp's PSU.
But UH-OH? What's the preferred lug (if any) to be connected to ground (outer foil)?
Ciao
Gianluca
Old 30th December 2005, 11:16 AM   #2
they are non polar
use either way
dave dove
Old 30th December 2005, 03:40 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
It matters
Here is a post dealing with the subject:
sexing caps
I sacrificed one of my Russian caps to determine outer foil. At least I'm sure now.
Old 30th December 2005, 04:41 PM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
So Frank, do I have to connect the outer foil to "ground" or to the lower dc potential side or it is the opposite?
Old 30th December 2005, 07:09 PM   #5
tarmac ripper
Gluca's Avatar
Outer foil to GND.
Thanks John. Quite an easy way to find the cap's sex. I did miss that thread ...
Ciao
Gianluca
Old 1st January 2006, 12:24 AM   #6
I sacrificed one of my Russian caps to determine outer foil. At least I'm sure now.>
Hello John - I have a stack of those russian Teflon caps - do please tell me which is the outer foil? the problem is that the sign on the cap is at 90 degrees so it's not clear. I'm sure you know what I'm talking about. Andy
Old 1st January 2006, 12:50 AM   #7
diyAudio Senior Member
fdegrove's Avatar
Outer foil to GND.
In the case of PSU filter caps consider the foil side as the - sign.
In case of a coupling cap consider the foil as analogous to the shield of a coax cable where you'd daisy chain the foils from one stage to the next.
Frank
Side effect mixed caps on psu ?? dytln_02 Power Supplies 15 8th March 2008 07:29 AM
Mounting speakers side by side jamikl Multi-Way 2 6th August 2007 05:01 AM
Low side driver as a High side fr0st Parts 0 8th May 2004 02:14 PM
Side fire sub, how close can magnet be to side? tim_rule Multi-Way 2 2nd February 2003 08:22 PM
Page generated in 0.10771 seconds (71.04% PHP - 28.96% MySQL) with 10 queries
