diyAudio Sponsor
Old 30th December 2005, 03:07 AM   #1
845amp is offline 845amp  United States
Default 717a plate volts
I know the data sheet shows the 717a plate volts at 120 volts..\
Is that Max, or can it be run higher without hurting it?
thanks,
Old 30th December 2005, 05:19 AM   #2
Tweeker is offline Tweeker  United States
Most of what I could find.
Be sure your foil hat has a good low impedance ground.
Old 30th December 2005, 01:06 PM   #3
hi Tweeker..thanks for your response... i just completed a 717a/45 amp and i am surprised at how good it sounds.... really has good detail, dimension and depth and it really fleshes out the sound....i have built upwards of 200 set amps to date, most of which have all used triode inputs, drivers and outputs, but lately i discoverd how good the pentode driver sounds with a 6sj7/px-25 amp i built and now this 717a/45 is a winner too..
but i find a lot of variation in the 717a plate volts between the various 717a's in the same socket.. as much as around 50 volts.. but out of the six 717a's that i have, i found a pr that run at about 111v and 116v... and i was wondering if the 120 volt spec in the data sheet is a hard and fast max for the 717a..
is the foil hat tied to pin one? and what is the benefit of grounding the foil hat?
thanks
Old 30th December 2005, 01:06 PM   #4
Default foil hats
<<Be sure your foil hat has a good low impedance ground.>>
lol ok i get your drift lol...
however since 717a's are notoriously microphonic <at least several of mine are>.. and the metal base is common with pin one, i was thinking maybe i should ground pin one.. didn't try it yet...
Old 30th December 2005, 01:32 PM   #5
SY's Avatar
It helps block the CIA mind control lasers being beamed from spy satellites.
Anyway, here's the datasheet It gives a 180V max plate voltage.
http://frank.pocnet.net/sheets/127/7/713A.pdf
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 30th December 2005, 02:34 PM   #6
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Hey Stuart,
You've got this one. It really made me ROTFL, like the word says.
Old 30th December 2005, 11:22 PM   #7
Screen voltage is listed at 120V though.
They would like to make you think foil hats dont help, but I know better. A good grounding in electromagnetism will let you see the light.
schematic from this amp 45/717a/5u4.. sonix Tubes / Valves 10 12th October 2011 04:08 PM
Matched pairs 717A Western Electric/Tung Sol phrarod Vendor's Bazaar 1 19th October 2007 08:15 PM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
717a Datasheet mrstone Tubes / Valves 7 5th August 2004 05:05 PM
Page generated in 0.09391 seconds (76.18% PHP - 23.82% MySQL) with 10 queries
