| diyAudio Sponsor | ||
Hello all...
One of my "dream" is to have and build a tube amplifier... I have already (someone give me) 3 ECLL 800... So if someone know know where to find some shematic for a diy around this tube...you 're welcome ! Sorry for my english...THX |
#2 |
#3 |
Thanks...
Yes I've work in electronic fabrication and repair But only in TV section so I don't know a lot of thing in tube... Have you got shematic for the power supply ? Is this amplifier good quality ? Can you tell me the detail of the component ? (watt of the resistor...value of condensator...) I know where to find the out transfo and power... Last question...does this schematic need a preamplifier ? Best regard |
#4 |
Yes...i need to know ...
The type and value of the condensateur... The power of the resistor If i need and preamplifier wich one ?(to work with CD player) A schematic of the power supply The 6.3V in DC or AC ? How many ampere for high voltage and hot circuit for one tube ? Can I test my tube before begin to build ?(i think no but...) If you can answer this...you 're the best.... I will put a tempo on high voltage...is it good? sorry i need all the detail to sart my project ....and learning... thanks a lot
#5 | ||||||||
#6 |
I just stumbled upon this thread (thanks to Dave for the idea...). I'm going to try to toss this together el Cheapo. Here are my thoughts on the iron:
Power: Hammond 261G6 (250v 130mA, 6.3v@2A) Choke: C354 Dynaco (1.5H @ 58ohm, 200mA) OPT: Hammond 1609 (10k) The total for the iron comes out to be about $110 The PSU is a SS CLCRC design, using 1N4007 diodes in full bridge. C1=120uF, C2=120uF, C3=100uF. R1 = 470 ohm, 15W I am still undecided about the heaters, although I think DC may be the way to go...Dependant upon where I can find these tubes, I hope to get this done under $200.... Thoughts ? -Steve |
#7 |
http://www.jogis-roehrenbude.de/Verstaerker/ECLL800.htm
I think one ecc83 'll be more than enough gain. Simon |
#8 |
Yes - I know...Which is rather unfortunate. But if you had the tubes on hand....
#9 |
Oops, overedited my last post...
In Europe you could try to find an old radio and pull them but in the US they'll be scarce.. I've got the parts from a radio, should be a nice little project (still adding a few grey hairs Simon |
#10 |
Simon,
Thanks for the help ! I was also thinking of an ECC83/12AX7 driver. That said, that is beyond the rating of the power transformer I selected (it is rated at 130mA), so I will have to find something abit hotter - which unfortunately means larger. I was trying to make a nice small unit; any suggestions on some nice small 250v, 150mA, 6.3v@2A units Thanks ! Steve |
| Someone help: SE shematic with GK71? | bezobraznia | Tubes / Valves | 30 | 24th April 2011 12:17 AM |
| For Sale: ECLL800 2 itt/lorenz 4 tungsram NOS | Westerp | Swap Meet | 7 | 13th October 2007 09:54 PM |
| 308/ecll800 Lorenz | larryscan | Tubes / Valves | 2 | 18th November 2005 01:57 AM |
| NEC A10 shematic | vd-two | Solid State | 0 | 5th April 2005 10:08 AM |
| shematic of vincent cd s1.1 | alchemy | Digital Source | 5 | 29th October 2004 01:31 PM |
| Page generated in 0.11917 seconds (78.88% PHP - 21.12% MySQL) with 11 queries |
