diyAudio Sponsor
Old 23rd December 2005, 07:23 PM   #1
mr mojo is offline mr mojo  United States
Default Question about PIV rating of diodes...
Howdy folks,
Well I've run into my first snag with my DIY amp-the bias network.
Basically I'm tapping the HV secondary for bias. Set up:
HV secondary in series with .05uf 600v Sprague Orange Drop cap. Next a diode (1000 PIV, 4 amp) in series with the cap, going to a trimpot. The junction of the cap and diode has a 27k 1 watt resistor going to ground.
Last week the .05 caps shorted and took out the 27k resistors in the process. Replaced the caps and resistors, but still having very erratic behavior with the bias.
Someone told me the Orange Drops were the issue, so I bought some PIO caps from Angela, but then I got to thinking:
Shouldn't the diode's PIV rating be 2.8 times the voltage of the secondary? I read elswhere a good rule of thumb is to make sure the PIV is 3 times the secondary voltage.
I'm thinking maybe the problem has been the diodes all along, so I'm putting in some 1,500v PIV diodes tonight and seeing if that fixes the problem.
Anybody got any insight into this diode situation?
Thanks for any and all help,
mr mojo
Old 23rd December 2005, 07:26 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Schematic? Voltage?
Old 23rd December 2005, 07:37 PM   #3
Hey poobah,
Having some server issues at work so I'm having trouble posting images, but if you check the post at the top of this link there's a working link to the schematic:
first DIY amp start up-yowza HELP!
800VCT, so I've got 400V on each half of the secondary.
Best,
mr mojo
Old 23rd December 2005, 08:17 PM   #4
poobah's Avatar
Hmmm,
You're talking about C25 & C26???
All I can think is that the voltage is just too much for the caps. 400 volts RMS means 566 Volts... if you are running right on high line voltage (125) instead of 117 you could wind up with 604 Volts. That should be right on the hairy edge but what if a spike came along? (they did both fail at the time did they not?)
You know usually there is good safety margin but these caps are seeing alot of AC current which heats 'em up, and eats the safety margin...
I wouldn't spend any money on boutique caps... the orange drops with a 1000 Volt rating would be better... the diodes in the circuit shoud have at least 800-1000 Volt. the diodes. You can put 2 diodes in series to jack up their PIV rating.
Why did 600 Volt papers work and not these... the papers weren't dealing with the nasty recovery of a jelly bean silicon diode maybe. I think all this is just TOO close to the limits.
Old 23rd December 2005, 10:49 PM   #5
Tom Bavis's Avatar
I would use at least a 1200V diode here, and at least a 1000V cap - cheap insurance. 1K or so in series with the .05 would reduce the surge current on transients, but it's probably voltage, not forward current that killed it.
Old 23rd December 2005, 11:04 PM   #6
poobah's Avatar
Hi Mojo,
Got to thinking... you said things have been erratic since.
You know if the caps failed and took out the resistors; it's quite likely the pots might have taken a beating as well. Just wondering about "erratic".
Old 24th December 2005, 12:24 AM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Not so, I'm afraid. Assume that the transformer charges the reservoir capacitor to its peak voltage of 400V x root 2 = 565V. Now the polarity at the end of the transformer/diode changes and it's at -565V. Your diode now has 1130V across it.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th December 2005, 04:04 PM   #8
poobah,
I really appreciate the help! Like I've said before, I'm not an engineer and the more I learn the more I realize how much I don't know!
I'm replacing the diodes with 1500PIV 1 amps as well as 630v PIO caps. The caps are temporary until I can order some 1600v Orange Drops when Antique re-opens.
Tom,
I think you and I are on the same page, your suggestion is just about exactly what I'm in the process of doing. Guess this is just part of the learning curve for me and part of the testing and evaluation of what's basically a prototype amp-even if the circuit was designed by the engineers as Westinghouse, it's not as if this is a widely built circuit with a lot of documentation from actual use!
EC8010,
Spot on-that's exactly what I'm doing. When I started researching diode ratings I came across the 1.6 FV and the 2.8 PIV rating and suddenly I beleived I had my answer-but like I said above I'm still scaling the learning curve so it's nice to have someone more knowledeable backing up my reasoning.
Thanks so much for you help folks-I really do appreciate it so much. This forum is the BEST!! I'll update this thread next week after my repairs. I'm also replacing the HV filter caps with 450v Spragues in series with voltage dividers so I'll post some pics of that whole affair as well.
Hope you all have a merry Christmas and a happy and safe new year!
Best,
mr mojo
Old 24th December 2005, 04:10 PM   #9
poobah's Avatar
Hey Mojo
You are most welcome. I are an engineer (a bad one), "and the more I learn the more I realize how much I don't know".
Hope you solve your problem!
Happy Holidays dude!
Old 24th December 2005, 07:12 PM   #10
amperex is offline amperex  United States
From years ago, problems went away when that 3x the PIV rating was used. Before Cary Audio existed, Dennis had some RF amps that had issues due to that rule.
811a rating question nhuwar Tubes / Valves 14 2nd March 2009 04:12 PM
Blackgate N voltage rating question KT Parts 1 28th July 2005 12:05 AM
A question about diodes... mr mojo Tubes / Valves 4 26th July 2005 09:16 PM
power supply diodes voltage rating? Dominique Parts 6 27th April 2005 02:45 PM
Current rating of diodes within a bridge? tiroth Parts 39 5th December 2003 03:26 PM
Page generated in 0.09883 seconds (88.33% PHP - 11.67% MySQL) with 11 queries
