| diyAudio Sponsor | ||
#111 |
what direction should someone (like me) take, that is wanting to improve his 500C go?
I'd like to bring mine into the present without changing the listening enjoyment this old design provides. I've noted the upgrade kit(s) and cap replace board from triode electronics (which i tend to shy away from) on fleabay and the suggestion to lower the bias a touch to prolong tube life. Any other suggestions without major modification? Thanks, pc |
#112 |
You must deal with the reality that old stock 7591s are "unobtainium". Thankfully, current production ElectroHarmonix 7591s fit. The "gotcha" is that the current production tubes are unforgiving of the liberties Fisher took with the max. allowable grid leak resistor value. Search this page from Jim McShane's web site for 7591. You will find what you need to know. Also, peruse the 7591 data sheet.
The changes Jim McShane outlined are the MINIMUM needed to ensure long term reliable operation. IMO, you should go further. Fisher's decision to use a 12AX7 as the driver/splitter was "counting beans". A 'X7 has POOR drive capability. The 7591 grid leak resistor value "cheat" is directly connected to the wimpy nature of the 'X7. Changing the splitter/driver twin triode to a 12DW7 permanently resolves the drive issue problem. Only the value of some resistors change. The topology is unaltered. An added benefit of the 12DW7 mod. is improved resistance to slew limiting. "Concertina" phase splitters should be built around high gm types. The 'X7 is low gm.
Eli D. |
#113 |
Hi all, new guy to the thread here...I actually just picked up a 500C today from someone that I work with (he's moving to Florida) and upon a quick search online, I wasn't too surprised to find a thread about the Fisher on diyAudio. I was wondering, aside from replacing various caps and tubes, are there any relatively simple improvements I could make to it?
This is my first tube piece (I'm only 25...I figure I have time ), it's hooked up to my Dynaudio Contour S1.4's and it sounds amazing. While I work on some other DIY stuff, this might be a perfect stopgap receiver before I get my separates together. I'm quite glad to have stumbled upon this thing. |
#114 |
Hi EvilYoda,
Some metal film type resistors in the input stages. The carbon comps can be noisy. Measure your resistors as those old ones may drift off value. Replace all the coupling caps if it hasn't been done. Replacing the electrolytic types would be prudent as well if they are original. Component type (general construction) is more important than the name. Avoid cheap parts, normal grade parts are more than good enough. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#115 |
Well...that was quick
I don't suppose there's a list anywhere of resistor/cap values and suggested replacement parts? The entire piece is original...he was even the original owner, since '64. As for the tubes, I've read that people are replacing not only the 7591A's, but the 12AX7's as well...I saw that EH has a 7591A tube, but I haven't heard much about the JJ one that's also listed on tubedepot. Aside from NOS tubes, have most people gone with one manufacturer or another?Thanks again for the help, this sound has me smiling nonstop right now. |
#116 |
E/Y,
JJ has been inconsistent of late in the quality of Octal based tubes they produce. OTOH, the Saratov, Russia plant, where EH tubes are made, has been doing an excellent job across multiple types. IF it's properly made, the JJ 7591 is good.The TFK ECC83s Fisher used are outstanding and should not be replaced until they are worn out. You could replace the phono section 'X7s with the quiet Sovtek 12AX7LPS and store the TFKs from those "holes" for future use elsewhere in the "box".
Eli D. |
#117 |
Ah, thanks for the advice...I won't be using the phono stage as one of my projects is a Pass Pearl phono, so no worries there. Guess it'll be the EH tubes for now!
Now I'm trying to figure out the best and safest way to clean the body, due to all the obstructions. Eventually I want to take the glass out to clean it...and I know one of my bulbs is out. |
#118 | |
1. Your experience is not the norm. I rarely if ever have trouble with EH power tubes, especially in the last few years. I have NEVER had a 6CA7 EH act up. 2. If you got a bad 300B out of the box I blame whoever sold it to you. Didn't they test it? After being shipped 1/2 way across the world I think they should be tested. 3. Right now, the pin soldering on EH stuff is the best out there by far - WAY better than JJ, that's for sure. 4. The one EH/Sovtek power tube I don't carry is the 6L6 though, so I cannot comment on those. 5. JJ 7591s don't like 330K grid resistors either. If you have one good 300B I'll be happy to match one up to it - just pay me for the tube, the matching is on me. Drop me an email if you like. |
#119 |
Hi EvilYoda,
Please, discontinue using it if it is original! If you experience a capacitor failure or rectifier failure you may lose some rather expensive parts. Never mind the tubes becoming damaged possibly. Losing a transformer is a very real risk here. The best thing to do is get ahold of the service manual or a clean (legible) schematic. There are some floating around if you don't have it yet. Study each section carefully. Go through and discharge each capacitor through a resistance. Read the safety section in this forum!!! After this, take a number of digital pictures from many angles at high resolution. You will be very happy you did this. Take a meter (decent digital, Fluke preferred or the new Agilent) and measure all the resistors. Note which are out of tolerance. Replace these with metal oxide, 1 W minimum (for the voltage rating). Low level stages may benefit from metal film resistors. Do everything, even the phono stage. The glass is easy to spoil. You will need patience and nothing more than water and soft cloth or paper towel. Never rub! You will lose the lettering for sure if you do. You must pat very carefully. Electroharmonix is my personal choice. I have not tried the 7591A's yet (I do need a set) but the 6L6EH have been wonderful. They sound great, just like my NOS tubes (I don't believe in NOS tubes). They are also very reliable. Any brand may have the odd defect, so don't buy them until you are ready to try them. Expect the odd noisy signal tube. Buy an extra or two. I've had 1 noisy 12AX7EH in over 5 years using these. Not bad really. -Chris
| Fisher 500C troubleshooting | mholz | Tubes / Valves | 6 | 28th April 2010 02:47 AM |
| Fisher 500C with JJ 7591S - Optimum Bias Current? | Scott Novak | Tubes / Valves | 4 | 30th July 2009 02:43 PM |
| faceplates and heatsinks for sale! (dialup warning) | cowanrg | Swap Meet | 26 | 23rd February 2006 01:27 AM |
| next project: rebuild using fisher 500c trannies | zobsky | Tubes / Valves | 27 | 15th March 2004 07:58 PM |
| Page generated in 0.13215 seconds (84.27% PHP - 15.73% MySQL) with 11 queries |
