diyAudio Sponsor
Old 23rd December 2005, 12:13 PM   #1
jackinnj's Avatar
Default Wall Wart Tube Power
I didn't have time to get a transformer for a project which is a Christmas gift -- here's what I hooked up -- the wallwarts are beefy 20 watt types used in Zip Drives -- as external drives are all USB now they are collected in a box in the shop -- if you are going to test out these small transformers use a conventional light bulb in series to "current limit".
Old 23rd December 2005, 12:22 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Please tell me that you aren't really using a half-wave rectifier for the heater supply! Half-wave rectification puts a very nasty load on a transformer because it causes it to pass DC - which easily saturates the core.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd December 2005, 12:39 PM   #3
jackinnj's Avatar
it's a full wave rectifier -- just too lazy to draw in all the diodes -- the left hand wall wart was left "intact" with its diodes and capacitor --
Old 23rd December 2005, 12:59 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I'm surprised the 5V 'wart TX doesn't saturate...
Old 23rd December 2005, 02:05 PM   #5
Send a message via AIM to DigitalJunkie
So it's output is DC?
Old 23rd December 2005, 04:29 PM   #6
Brian Donaldson's Avatar
So your putting 9v into the 2.5v worth of coil. Unless your getting out 400v+, your asking for drama.
You know better than that.
Oh wait, I see, it was 2 diode half bridge. Your only 100% above rated voltage.
Old 23rd December 2005, 06:52 PM   #7
jackinnj's Avatar
with 117 VAC in I am getting 353VDC out of the voltage doubler and 6.299V to the filament.
note that the adjust leg of the LM317 is NOT connected to ground -- it floats.
Old 23rd December 2005, 08:23 PM   #8
EC8010's Avatar
I'll bet you really wish you hadn't started this thread...
Have you looked at the voltage waveform going into the HT voltage doubler? If it hasn't got flat tops then your transformer core isn't saturating.
Old 24th December 2005, 07:16 AM   #9
frugal-phile(tm)
planet10's Avatar
Do i smell smoke?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th December 2005, 02:25 PM   #10
jackinnj's Avatar
no smoke yet -- there seems to be about a diode drop's worth of DC on the transformer coupling -- so there is some saturation going on -- this under load -- the temperature rise (can only measure the exterior of the transformer with a laboratory thermometer) is a few degrees C after 1/2 hr.
and the waveform (not pretty) between the two transformers (you can see the diode ringing.)
wall wart and basswood BluesMagoos Analogue Source 6 9th September 2007 09:54 AM
Wall Wart for testing bal704 Chip Amps 6 23rd October 2006 01:47 AM
best wall wart for t-amp, where? gychang Class D 3 2nd October 2006 12:06 PM
2 Wall Wart PS Question Sherman Chip Amps 13 22nd February 2005 09:25 PM
Page generated in 0.12130 seconds (71.76% PHP - 28.24% MySQL) with 11 queries
