| diyAudio Sponsor | ||
For some reason I don't remember seeing any schematics for a diff pair of DHTs with a CCS. My balanced line stage already uses a diff pair of 1626 with a Morgan Jones type CCS (as in his book, p.134). So how do I deal with the filaments of a DHT? I've never used DHTs but I need to know so I can try out some 26s in the first instance, then one or two other DHTs. Can somebody talk me through this (schematics very welcome) for:
a) AC filaments b) DC filaments - probably necessary with a 26 Thanks for your help here! I don't know if this is simple or difficult - never seen it done. Andy |
#2 |
diyAudio Moderator Emeritus
AC:
Cross-connect the heaters in parallel to cancel hum. Connect CCS to centre tap of FLOATING heater transformer winding. DC: Parallel heaters, cross-connected is better to reduce effects of ripple. Connect CCS to negative of FLOATING DC heater supply. Edit: Added FLOATING to AC case. |
#3 |
AC:
#4 |
DC:
#5 |
Thanks, John, that's very helpful. With the aid of some D cells I might be able to get my 26s up and running to see what they sound like. Andy
#6 |
You probably know about Gary Pimm, if not google him up. He has some good info on implementing CCS's in various circuits, push-pull included, in his article "CCS's and signal current control".
| Low plate voltage pentode (<40v) for diff pair? | Rescue Toaster | Tubes / Valves | 3 | 2nd September 2006 12:56 AM |
| 6SL7 diff pair - how to set up???? | andyjevans | Tubes / Valves | 24 | 16th March 2005 12:15 AM |
| Aleph-X, higher diff pair bias? | acaudio | Pass Labs | 3 | 14th March 2005 07:39 PM |
| Output stage/preamp with gain: X-Bosoz with diff.-pair? | Onvinyl | Pass Labs | 1 | 19th July 2004 08:29 AM |
| Heatsinking the input diff pair? | AudioAngel | Pass Labs | 8 | 27th June 2004 10:53 PM |
| Page generated in 0.09089 seconds (72.52% PHP - 27.48% MySQL) with 11 queries |
