diyAudio Sponsor
Old 22nd December 2005, 06:50 PM   #1
Default Just need to make sure.
OK I am way new to tubes so I just want to make sure I am not wrong. Looking at the schematic for pins 1, 2, 5, & 6, and comparing them to the pic of the socket, is not 1 & 2 numbered wrong, and need to swapped, 1 on the bottom, 2 to the left, or am I completely confused.
Old 22nd December 2005, 07:00 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I don't see any problem..
Old 22nd December 2005, 07:26 PM   #3
Is not 1 & 2 numbered wrong on the schematic in relation to the pin layout pic.
Old 22nd December 2005, 07:45 PM   #4
dhaen's Avatar
The schematic is just a representation and can be drawn as the draughts-person desires, as long as pin1 is the control grid, and pin 2 is the cathode, that's all that matters. It could even be drawn mirror-image.
The socket or base layout is a physical thing, so has to relate to the pysical nature of the object, that can't be drawn any differently.
Have a look at the 6aq6 datasheet on this page for comparison. You will se that the schematic symbol is drawn quite differently (which is allowed), but the socket/base is the same.
Old 22nd December 2005, 09:29 PM   #5
I understand now after seeing the pinout.
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 11:08 AM
What to make? Mayday Tubes / Valves 3 5th December 2006 03:20 AM
Make ac dc. Jasmeleg Parts 12 12th September 2005 06:14 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Page generated in 0.08900 seconds (69.10% PHP - 30.90% MySQL) with 11 queries
