diyAudio Sponsor
Old 21st December 2005, 04:41 AM   #1
dsavitsk's Avatar
Default center tap of heater winding
I am using a EZ81 rectifier tube for my line stage (based on pete millett;s low mu pre but usinf 6080) which is indirectly heated. The 6.3v tap of my transformer is center tap'd. Should I ground the center tap, not connect it, or something else?
If it matters, the gain tube is also indirectly heated, but is heated with a tap from a different transformer -- about which I have the same question, actually.
Thanks,
-d
Old 21st December 2005, 09:10 AM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
With the EZ81 winding, I think it hardly makes any difference where it is connected, but it shouldn't be left floating. The most reliable way would be to connect it to the cathode.
I see that on the Low mu pre , Pete has elevated the signal heaters with 2 resistors. If your other winding has a centre tap, then they should connect to this.
Old 21st December 2005, 10:11 AM   #3
Send a message via AIM to DigitalJunkie
I dunno if grounding it would be good.The cathode at B+ and the filament inside it at ground potential. -potential arcing?
The cathode would probably be a good bet.(assuming the winding insulation is up to it.)
The CT on the winding for the gain tube can be grounded,or connected to a voltage divider to elevate the filaments a few volts above ground,to help reduce hum.
Old 21st December 2005, 04:36 PM   #4
dsavitsk's Avatar
Thanks for the responses. I think I'll try the cathode first, and if that doesn't work and I have noise I'll move on to something else like grounding.
Why might there be arcing if the heater is at ground? The transformers are 125-0-125 leading to a B+ of about 140V
Pete said that the reason the heater is elevated is that the EL34 in the CCS can only take a limited voltage from plate to heater, and this is to lower that potential. In my case, I am using a solid state CCS and thus a much lower B+ which aleviates this problem.
Old 21st December 2005, 04:40 PM   #5
dhaen's Avatar
In that case there is little reason to elevate.
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
Heater winding load question. G Tubes / Valves 3 22nd May 2004 06:40 PM
grounding heater/filament center metebalci Tubes / Valves 6 27th March 2004 08:24 AM
Center to Center of Drivers 29" apart in proposed config - Problems?? Ken L Multi-Way 14 3rd November 2003 12:49 PM
Page generated in 0.07682 seconds (77.58% PHP - 22.42% MySQL) with 10 queries
