| diyAudio Sponsor | ||
Looking at this picture, do you think this amp has enough capacitor for 60W per channel? I zoomed in the picture and I think each is about 100uf which would give 300uf total.
This is mono block so it's 300uf per channel. |
#2 |
#3 |
More than sufficient. Vintage amplifiers in this power rating generally had far less capacitance and generally sounded fine. (In many cases less than 100uF total.)
Beyond this it gets more complicated. Adding additional capacitance is not a panacea for bad design. Kevin
www.kta-hifi.net |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.06705 seconds (70.52% PHP - 29.48% MySQL) with 10 queries |
