| diyAudio Sponsor | ||
I had an idea to use a PP transformer in a SE amp by using one half of the primary with the triode like any SET amp, and a current source feeding the same curent into the other end of the tansformer. My thoughts were that I could use a much smaller and cheaper ungapped PP transformer, but wanted to ask if anyone has done this and how did it sound. (actually, I could use a much bigger triode as I can't find a SE transformer over 50W)
I wanted to avoid parafeed because of the big cap needed. |
#2 |
On Plitron's site under special designs I found this:
PAT HQ5090 Application: Svetlana SV572 Triode 90 Watts This Single Ended output transformer is intended for paralleled Svetlana SV572 triode tubes, with a primary impedance of 2.5 or 5 kOhm, depending on secondary loading. Secondary impedances are 2, 4 and 8 Ohms. The -3dB bandwidth is from 8 Hz to 43 kHz with a high frequency Q-factor close to 0.5 (critical damping). The insertion loss is an extremely low 0.15 dB ensuring no loss of audio power and creating excellent damping at the low frequency end of the power spectrum. The DC current capability is 400 mA maximum. This transformer is designed for no overall negative feedback applications, completely relying on the tube characteristics for the purest sound quality. I couldnt find any further information though.
Be sure your foil hat has a good low impedance ground. |
#3 |
Hammond 1642SE
75watts 5,000ohm impedance 300 ma. max DC bias 4-8-16 ohm taps 3,500 V RMS hipot 28 pounds
#4 |
$611 each for the Plitron...ouch I was looking for 200watts worth for an 833A, but if I can't find the iron at a reasonable cost, I may just do an OTL 6C33C x6 amp. I was thinking maybe the 280W they sell for PP. Any comment on counter-biasing a PP tranny I need 1800 ohm or so 400 to 500 ma. |
#5 |
Why not try to parallel two Hammond 1642se?
#6 |
I´ve had similar ideas but never tested anything out.
Maybe pentode for the CCS and a similar pentode (but triode wired) for the signal side? |
#7 |
ccs side, I'll go sand. Maybe even OP amp servo controlled mosfet tuned to low frequency like .5 hz.
I may have to try it on a smaller scale first. |
#8 |
#9 |
Somewhere there a discussion of an amp with a triode on top and pentode on the bottom, with the gain mostly coming from the triode, but I cant find it.
#10 | |
I tried the custom transformer route, through a transformer winder who builds good 300B transformers, but the 200 watt SE transformer didn't quite work as good as his computer program said it would. It is good enough for a 200 watt SE guitar amp, which is currently being breadboarded. The CCS load on the other half of the transformer trick does work. I tried it at the 8 watt level using a 300B on one leg of the transformer, and an IXYS 10M45 on the other leg. To get 200 watts out of an 833A, I had to run 1500 volts. That voltage tends to turn silicon back to sand if you are not careful. I have been experimenting with hybrid CCS's. There is a thread discussing the results of a few peoples experiments along these lines. Active load output stage
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.11725 seconds (77.65% PHP - 22.35% MySQL) with 11 queries |
