| diyAudio Sponsor | ||
Is it okay to use two irons, one to supply the plates and another for the heaters? their centertaps will be joined to form a common ground.
#2 |
perfectly ok, even makes it easier to implement standby/on function.
#3 |
diyAudio Moderator Emeritus
It's recommended for noise improvement.
#4 | |
why not? irons are still very cheap in our country, costs just over a us dollar per kilo, while copper costs an average U$7.5 if you have plenty of space on your chassis, this can be done easy.
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#5 |
I usually use two, or three irons for prototyping and they sound great
1 x HV + grounded heaters 1 x Floating heaters 1 x Bias Even in the final model it only gets reduced to two, because I have floating heaters in mu-followers and/or a tube regulator supply. |
| Amp that has the biggest number of irons | vax9000 | Tubes / Valves | 3 | 26th July 2006 04:42 AM |
| Opinions on soldering irons/stations? | Christer | Equipment & Tools | 42 | 30th December 2005 06:35 AM |
| What Soldering Irons dou you guys use? | bigparsnip | Parts | 51 | 24th September 2003 11:48 PM |
| Your opinions on ERSA soldering irons. | rendisha | Equipment & Tools | 4 | 13th August 2002 09:07 AM |
| Page generated in 0.09598 seconds (72.59% PHP - 27.41% MySQL) with 10 queries |
