diyAudio Sponsor
Old 18th December 2005, 08:51 PM   #1
Default I need a simple schematic with 6J1P tubes
I have 4 new tubes(they are russian tubes ) and I want a tested schematic with them and if it`s possible with a pcb.
I know these tubes are equivalent with ECC88 or 6DJ8.
I also found a schematic named Cavalli Jones headphone amplifier(Cavalli Jones ) but i don`t know how to connect the tubes and how to design the pcb. I also mention that my tubes are very small and they have just 7 pins and in that site I saw that have 9 .
I really need help because it is my first project with tubes.
Old 18th December 2005, 10:30 PM   #2
6n1p pins out the same as a 6922 and it will substitute for the 6922 SOMETIMES, IF the 2X heater current is available.
The 6j1p is a 7 pin pentode. 6j1p Data Sheet
Eli D.
Old 19th December 2005, 03:47 PM   #3
ok but has someone any schematic with these tubes?
if he/she has one i ask him/her to post it here or to give me the link please
Old 19th December 2005, 11:30 PM   #4
leadbelly's Avatar
The reason you are not getting many replies is that there are SO many choices if you search for 6922 or ECC88. Also, you have said hardly anything about what you want to DRIVE with those tubes. Drive a solid state power amp? Make a headphone amp?
EDIT: Sorry, I see I misread the thread and you are looking for a project for the 7 pin pentode instead of 6922 equivalent
Aerodynamics are for people who can't build engines. Enzo Ferrari
sweept tubes for simple Se recommendation? dubdub Tubes / Valves 6 31st March 2009 01:25 AM
Simple SE Schematic jobsworth` Tubes / Valves 11 6th October 2008 02:41 PM
simple matching philosophy on tubes.. GeirW Tubes / Valves 1 17th February 2004 07:20 AM
a simple preamp with 5687 tubes karma Tubes / Valves 3 23rd April 2003 08:44 PM
Page generated in 0.08673 seconds (72.37% PHP - 27.63% MySQL) with 10 queries
