diyAudio Sponsor
Old 15th December 2005, 05:53 PM   #1
Send a message via MSN to DoomPixie
Default 6DJ8 Linestage
Hey all, I have been experimenting with my 6DJ8 linestage and have changed a few component values and came up with the following, It sounds better than it did originally, anyone got any suggestions for me to improve it further?
Owen
Old 15th December 2005, 10:38 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: 6DJ8 Linestage
Owen
is it 0,2uF enough for your power amp?
suggestions?
toss that SRPP ,wire both halves in para,then use some nice choke in parafeed ,mebbe even in WE config, burn them on some 90V and 20mA
and enjoy
after that -you can use some other tube in WOT style
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 16th December 2005, 08:59 AM   #3
i built 3 6DJ8 pre's last year and this one sounded best out of the three (to my ears at the time anyway)
Since then i have changed the value of the output capacitor from 0.6uF to 0.2uF and it sounds better BUT i was useing some really cheap 0.2uF caps to get 0.6uF and now i am useing some nice 0.1uF caps i got out of an old osciloscope that was going to the scrappers. so mabey the change for the better has to do more with the quality of the cap's than with the value?
Owen
Old 26th January 2006, 01:37 PM   #4
ok, just thought i would revive this thread, i have just replaced the output cap's with some nice 2.2uF cap's i bought... yet to test it with the new cap's in.. anyone have any sugestions how to improve this further?
Owen
Old 26th January 2006, 03:46 PM   #5
hacknet is offline hacknet  Singapore
whats the kinda current running through those babies? it might be a good idea to float the heaters so the top valve's heater insulation doesnt give problems.
Old 26th January 2006, 05:20 PM   #6
i'll measure the current tommorow. not sure what it is of the top of my head. might ad another RC stage to the power supply aswell to get rid of the remaining hum (only just noticable with volume maxed out and no input signal) and tweak it a little so the B+ is closer to 200V..
Owen
Old 27th January 2006, 11:34 AM   #7
Why don't you convert it to the Aikido circuit? This will get rid of any noise and from a performance aspect the Aikido will smoke it.
Old 27th January 2006, 05:31 PM   #8
to be honest, i dont think there will be any noise problems atall when i have sorted the power supply out properly. have you got any schematics for the Aikido? how many tubes does it use?
Owen
Old 29th January 2006, 07:39 PM   #9
turn it into a mu stage, definately improves the srpp no matter what some say.
a 10k or 20 k resistor above the top resistor, a 1MEG also and a coupling cap is all you need.
Old 29th January 2006, 07:45 PM   #10
Tube count increases
I will try to post a schematic
An almost DIY 6DJ8 Linestage JesseG Tubes / Valves 37 17th November 2007 11:43 PM
Information 6DJ8 npr Tubes / Valves 2 4th October 2007 05:31 PM
6DJ8 for MC without bias. ashok Analogue Source 35 3rd July 2007 12:35 PM
6DJ8 Tubes Tom D Tubes / Valves 24 26th June 2006 11:39 AM
Page generated in 0.10144 seconds (75.65% PHP - 24.35% MySQL) with 11 queries
