| diyAudio Sponsor | ||
I should have posted this question BEFORE I won the bid on a pair on eBay.
Anyhoo, they are a 1:14 mic input xformer (250 ohm ct: 50K). I plan to use them with a Denon 103R with a secondary load of 20k to reflect 100 ohms to the cartridge. I know they will work, I don't know how well . I'm hoping someone here has some experience with these, and can tell me if I either scored or got burned sound quality wise. You know, before I actually hear them to make my own determination Oh ya, I got 'em for $49.80 for the pair. Thanx, Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#2 |
Hello , i have tried the XT-3 [similar maybe] with very good results , better than swowter and other mc x formers
#3 | |
Thank you for the info, it will be a while before I have my analog front end up and running..I have to finish my turntable first Corian Turntable Fun ...as you can see it may be a long while Casey
#4 |
I forgot to ask..
What cartridge and loading do you use with it ? How did you wire it for best results ? Thanx again, Casey
#5 |
Hello, i have two cartridges, one is ZYX RS20-02 and the other is ORTOFON MC30. I have a 27 KÙ resistor parallel with secondary coil, and one 270 Ù parallel with the primary coil , also i use a low capacity interconect cable , the results are excellent, and the sound is smooth and clear .Try something like this...Gianis
#6 | |
Did you have any trouble finding the MIP9 socket for the XT-3? Did you use the full primary winding or half winding? Wondering what step up ratio you used and if/how you loaded the secondary winding. Which cartridge did you use? thanks, msl |
#7 |
Hello .. for XT-3 i have a secondary load 27 kohms to reflect lower ohms in primary coil, i use the full primary winding [ better response]. I was lucky , i found 9 pins socket but is very rare i think
#8 | ||
This socket, is it like an octal with an extra pin ? Is the 9-pin listed mid way down this page the correct one ?... http://www.surplussales.com/Tube-Soc...ubeSkts-3.html Thanx P.S. this thread may be more at home in the Analog forum. I posted my question here because this forum has a lot more activity...if you moderator dudes want to move it I understand
#9 |
Yes,, the socket for XT-3 is an octal with one extra pin, the same which i saw at Surplus sales site, with code 9P-SK/O. Gianis.
| Harmon Kardon | argonrepublic | Solid State | 2 | 23rd June 2009 07:30 AM |
| harmon kardon T-40 | jaudio | Analogue Source | 0 | 24th October 2007 11:37 AM |
| Harmon Kardon Receiver | JBjohnson | Vendor's Bazaar | 0 | 27th May 2007 03:49 AM |
| Harmon Kardon T40 | jaudio | Analogue Source | 0 | 7th May 2005 12:04 PM |
| Harmon/Kardon AVR35 | nitryce | Solid State | 1 | 5th May 2004 02:22 PM |
| Page generated in 0.11040 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
