diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   replace 6N1P with 7308 (http://www.diyaudio.com/forums/tubes-valves/69427-replace-6n1p-7308-a.html)
dsavitsk 9th December 2005 07:46 PM
I built a pair of Welborne DRD 300B amps. They use 6N1P's for the driver tubes, and I am wondering whether it is a) safe, and b) a good idea to put 6DJ8/6922/7308's in instead. I have a pair of Amperex PQ 7308's that I have no other use for (no, I won't give them to you -- I am sure I can find something to do with them,) and it seems a shame to leave them in a drawer.
As I understand it, the tubes are pin compatable, the 7308 will draw less heater current, but I am unsure how different the operating points are?
gorgon53 10th July 2007 03:51 AM
some taughts on OPTs...
bifilar winding of the transformer is a keyfactor in reducing distortion of other than class A biased PP operation. If we choose PP we should go parallel-PP (circlotron, McIntosh) because only then we can go bifilar with lower winding capacitance and hf-copper losses. One of the mainprobs with transformer windig are the core dimensions. They are optimized basically for 50/60Hz use and low production costs. What we need in audio is a WIDE and NARROW window, like we have in a toroid. Unfortunally, toroids without airgap arent what we need. If we introduce a distributed airgap it will increase copper losses and winding capacitance far more in the toroid than in a conventional EI cored transformer. So why not forget about PP transformers alltogether and make a real big airgapped EE-core and go single ended?
What would we loose? Power? Efficience? Sure... BW? Not so sure...if we get the right core...
What would we gain? I imagine small signal linearity....
might be worth it....
gorgon53 10th July 2007 03:59 AM
oops...
went into the wrong place...
should have been a new thread....
sorry
Resources saved on this page: MySQL 18.75%
