diyAudio Sponsor
Old 8th December 2005, 02:52 PM   #1
Default feedback phasing
I am building this guitar amp for my son and I dont have data about phasig feedback across output transformer.
I made analysis myself and figure out the phasing as shown with dot convention on schemaric below.
Is it good or am I wrong.
Old 8th December 2005, 05:56 PM   #2
Joel is offline Joel  United States
Joel's Avatar
You'll know right away just by trying it. Either it will lower the gain, or raise it. If it lowers it, you have the connection correct, and are applying negative feedback.
Joel
all possible permutations of series parallel and phasing amplexus Instruments and Amps 0 23rd December 2008 11:31 AM
Orientation and phasing of transformers? Skorpio Solid State 0 29th July 2008 12:35 PM
phasing problems on front components bser Car Audio 1 14th December 2004 03:32 PM
Phasing Tweeters ZiprHead Multi-Way 1 15th December 2001 12:23 AM
Page generated in 0.06157 seconds (64.73% PHP - 35.27% MySQL) with 11 queries
