| diyAudio Sponsor | ||
#11 |
diyAudio Senior Member
Ola hombre,
On this particular occasion I advised this type of filtering. On any rectifier tube you will have the recommend value of input cap given by the manufacturer. Generally,nothing against CLC filtering. You should try a choke with your preamp for a sonic blast away experience. Brett, Send some "poulet roti" my way please! Not polluted by mercury if possible? Buenas noches, Paco
Frank |
#12 | ||||||
I also have a lot of jokes about, special tube handling proceedures, red hot anodes and appropriate mountings, but I won't mention them here or the fuddy-duddy's will have apoplexy. Quote:
Ciao |
#13 | |
Hi Brett,
And you wonder why Grey is complaining about USA levels of education? I could go on about that problem ad infinitum.Frustaaating! Quote:
Now I should really hit the sack,5.49 AM here... Ciao too,
Frank |
#14 |
THANKS
PACO ! |
#15 |
With mercury vapor rectifiers you should wait a minimum of 4 minutes warmup time before applying the high voltage. Hallicrafters actually says in the HT45 manual that 15 minutes is preferable (this is a solid kilowatt linear amp from the 1960's.)
The ARRL handbooks of the 1950s and 1960s often discussed the noise with mercury rectifieres. |
#16 |
I have used 866A with good results.
Let the tubes stand upright for a week or so before applying filament power. And KEEP them upright or start over! Run the tubes on filaments only for a couple days before applying B+ for the first time. Check the filament voltage and adjust as needed before applying B+. Noise? I got no stinking noise ![]() L-C-L-C filters work well. Happy Ears! Al |
#17 |
I had always assumed that designers put mercury rectifiers in farady cages to limit the effects of the rf noise they produced, but if the following is true then maybe it was the other way round:
(RCA data sheet for 872 rectifier) "Shields and rf filter circuits shuld be provided for the 872-A if it is subjected to extraneous high-frequency fields during operation. These fields tend to produce breakdown effects in mercury vapour and are detrimental to tube life and performance" "Rf filters are employed to prevent damage caused by rf currents which might otherwise be fed back into the rectifier tubes" |
#18 |
Thanks for the tip on the RCA 827-A data sheet, very informative. My understanding is that mercury vapour rectifiers have a negative resistance at part of their IV characteristic and that this can combine with the leakage inductance and stray capacitance of the mains transformer to produce a circuit that can oscillate if excited. Since the system is excited at a 50Hz (or 60Hz) rate, this can lead to squegging at a 50Hz rate. Ferrite beads are usually touted as the cure. The RSGB and ARRL manuals are good places to look for information on using these rectifiers.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#19 | |
Brett, If you want serious DC for a transmitting tube power amp and ALSO want to cook chickens, forget Hg recifier tubes and just use microwave oven magnetrons as the rectifier diodes!
I.Q.Test. Have you ever purchased a recreational snowmobile? |
| Water vapour speaker? | bigwill | Planars & Exotics | 4 | 31st May 2007 09:29 PM |
| Mercury Vapour rectifiers | Craig405 | Tubes / Valves | 16 | 14th February 2006 03:34 AM |
| 866A tubes | WALTER BURKHARD | Swap Meet | 0 | 27th June 2003 03:07 PM |
| Mercury rectifiers | gimpus | Tubes / Valves | 11 | 26th April 2002 03:59 PM |
| Page generated in 0.13953 seconds (74.32% PHP - 25.68% MySQL) with 10 queries |
