| diyAudio Sponsor | ||
I am in possession of a pair of Heathkit A-9 amps (a heathkit A-9 and an A-9c respectively). I am unsure of their condition. One was rescued from a local radioshack (long story, but they were just going to throw it out, and the other was picked up off of ebay.
I'm unsure of either of their working conditions. I still need to pick up a variac and power them on slowly to check them out. That said, I'd like to see what the general opinion on these amps are. Is it worth doing a complete tear-down and rebuild with quality modern components? Or would I be better off just repairing any faults and using them as-is? Both amps have a little bit of rust and some paint chips. I figured that if I did a complete tear down, I could also restore the chassis and transformer housings. I can take pics if anyone is interested. Sorry if this seems like a strange request. I haven't found much info on how these amps sound.. I've only built a few tube projects, so tearing these down will be a major undertaking.. But if the results are worth it, I'm willing to do it! Thanks, Mike |
#2 |
Replace the bad caps - that's ALL of them. Measure the resistors and replace any that are off-value. Add a FUSE to this sucker! a 3-wire line cord is a REAL good idea too.
I have a schematic for the A-9A if it's any help... |
#3 |
I had a pair of those. Mine had an EF86 preamp tube. Not a good sounding amp, but the audio transformer is excellent.
They are a great platform to modify & will save ya a bunch of money regarding the existing good parts- chassis, iron, etc. BTW- I have a close to mint A-9 face plate. Need it to have matching pair? I will mail it to you. |
#4 | |
Joel |
#5 |
John Atwood shows some pretty good measurements on the A9 tranny.
http://www.one-electron.com/trans_p1.pdf
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 | |||
I have the manual that came with one of them, which includes all the build instructions (near mint! pretty neat to see how they did it back then). But if you have a PDF of the A-9A, it'd be nice to have on hand for comparison sake. Quote:
Thanks Amperex! That'd be great.. As far as i can tell, the only difference between the A-9 and the A-9C are the fact that the C has a light on it. If the transformers and output tubes are a decent enough, it sounds like replacing the input stage would improve the sound quality? Quote:
#7 |
Those aren't "grades" for square wave response - they're a list of waveshapes. read it all
#8 |
Thanks for pointing that out. I was poking around, trying to find the page that referenced that PDF, but gave up after 10-15 minutes and thought I'd tackle it again in the morning.
| Heathkit A7(c?) Rebuild | kenpeter | Tubes / Valves | 5 | 28th June 2008 08:46 PM |
| Heathkit W-5M rebuild | firenewt | Tubes / Valves | 29 | 7th October 2006 12:09 AM |
| RE XXX...Rebuild? | DKAudio | Subwoofers | 0 | 16th January 2006 03:01 PM |
| Help with amp rebuild | zeke | Tubes / Valves | 15 | 4th October 2004 01:39 AM |
| HFT-90 anyone rebuild one before? | ajhawkins | Tubes / Valves | 10 | 12th July 2003 05:38 PM |
| Page generated in 0.10649 seconds (77.16% PHP - 22.84% MySQL) with 11 queries |
