| diyAudio Sponsor | ||
#21 |
I knew that I had been there, my daughter was in a cheerleading competition there a few years ago. About those mushrooms, there is a field west of town............
In the sand state world, making smoke is expected. Every once in a while something actually works. The more transistors that you connect together, the more your chances of smoke. Connecting tubes and transistors together and turning the power supply up to 500 volts, created a lot of smoke, but now that I tamed it, it does sound nice.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#22 | |
Properly applied to the old Marshall next to it, it sounds like The Lord Has Returned! (carrying a 10 ton chainsaw.)
"Every time I go to town, the boys all kick my dog around." |
#23 |
On the advice of folks here, I'll be first trying a feedback amp with the 7591s in pentode mode. Since the Fisher iron I have was designed with that app in mind, it's probably the best fit.
I still want to try using a 6CM7 for the preamp/splitter, with the small triode as the preamp. I'm thinking of using the circuit shown below to feed a classic concertina splitter. Probably too much sand in the circuit for a lot of folks here, but I think that sand and vacuum can be used to complement one another... Values will follow when I have some time to stare at the tube curves for a while. I'll probably run the input stages using a 250V regulated supply. |
| Fisher 600 questions | akimball442 | Tubes / Valves | 25 | 13th July 2008 07:47 PM |
| Fisher 400 questions | pageboy | Tubes / Valves | 19 | 16th May 2008 02:44 AM |
| Fisher 500B Schematic Question | wrenchone | Tubes / Valves | 5 | 23rd August 2006 11:57 PM |
| old Fisher speakers, newbie questions | dtw2112 | Multi-Way | 2 | 30th May 2005 02:45 AM |
| Fisher RS-1020 questions and problems | Jeffy74 | Solid State | 0 | 18th April 2004 08:40 PM |
| Page generated in 0.06962 seconds (79.47% PHP - 20.53% MySQL) with 11 queries |
