diyAudio Sponsor
Old 6th December 2005, 08:17 PM   #1
Default EF86 penthode
Hi everyone,
I found a good tube amplifier project in an old electronics magazine;it uses a EF86 penthode and a couple of EL34 tubes in push pull as output stage.
Trying to build it I came across a problem with the EF86 tubes that are quite difficult to find,so I'm wondering if there is any current production vacuum tube that I can use in place of :Could anyone help/advice me on this?
Any useful reply will be very appreciated!
Thanks very much
Sincerely
Old 6th December 2005, 08:52 PM   #2
If you wish, there are several european distributors you could check out. I normally order from Ask Jan First and even shipping is very affordable
"There's something organic about a happy cloud of electrons" - Neutron Bob
Old 7th December 2005, 12:26 AM   #3
rdf is offline rdf  Canada
rdf's Avatar
Available, if not exactly dirt cheap:
http://www.tubedepot.com/so-ef86.html
Old 7th December 2005, 10:22 AM   #4
Thanks for your kind replies.
But really I would replace the EF86 tube with a current production equivalent tube;Do you know someone?
Old 7th December 2005, 10:47 AM   #5
SY's Avatar
The Svetlana is the only current production EF86 I'm aware of. Small signal pentodes as production items are rare birds these days, since the guitar market doesn't use them much. But NOS are plentiful, and a little bit of looking turned up lots of candidates at $15 or less. If you're worried about the future, in a decent circuit where care is taken to avoid turn-on and turn-off trauma, three or four spares will last you a lifetime.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th December 2005, 11:32 AM   #6
SY, I know opinions differ a lot on this issue, but would you care to expose your vision of a decent circuit? Does this apply for both signal and power tubes? Or should we better start (another) new thread to discuss it?
Thanks, many thanks
Erik
Old 7th December 2005, 01:09 PM   #7
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
i could not find the EF86 in india so am looking at a ckt using 6SL6 and 6SN7 instead but that is being discussed on another thread.
BTW what is this talk about a "decent ckt"? Are the ckts now available on the net not decent?
I found a bunch of ckts published on the net. see post 8 and 10 in the link below. which would be classifed as "not decent"?
EL34 schematic confusion
I'm not questioning anyone here all I am afraid of is getting tubes and OPTs for a ckt that is not good.
...still looking for the holy grail.
Old 7th December 2005, 05:01 PM   #8
SY's Avatar
Erik, I was really referring to taking care that the heater shock on turn-on is limited and that the circuit doesn't expose the tube to too high a voltage before warmup. Those are pretty easy objectives to achieve, though through dint of extraordinary effort, some intrepid souls have managed to avoid achieving them....
The heater issue is discussed in great length in Morgan Jones's book with some excellent examples.
Old 7th December 2005, 05:38 PM   #9
Hi SY
Thanks for your reply. I recently got Morgan Jones Valve amplifiers as a graduation gift and (re)read most of it.
The lovely Lm317:
- Reduces the frightening inrush current,
- seems to be good for the sound, ie, some people who compared an (indirect) heated valve feeded both from a voltage source and from a current source, prefer the current source,
- a simple CCS, sufficient to get your feet wet on this terrain.
Erik
How much feedback for PP penthode? Svein_B Tubes / Valves 18 25th October 2007 03:46 PM
How to change this design from penthode to triode or UL wrangler Tubes / Valves 8 2nd November 2006 02:51 PM
6l6 penthode triode vlljpior Tubes / Valves 1 28th October 2006 08:53 PM
47 Penthode in triode mode. Diy martin Tubes / Valves 6 24th September 2005 01:16 AM
Page generated in 0.10385 seconds (76.05% PHP - 23.95% MySQL) with 10 queries
