| diyAudio Sponsor | ||
Hello Folks!
I'm very proud of being a member of this forum, it's so full of friendly and helpful people (and very clever too) So I have just found 2 of these tubes: I know there's nothing like a useless tube, but these might be the exception So what can I do with them? I just found them in a box, don't know whether they've been used or not, but they look like new. The only data I could find was: http://4tubes.com/All-Files/datashee...tml/ER21A.html ps in the same box I found 3 GE EL84, 1 Siemens EL84, and various 12A*7 Sylvania, GE, Siemens... and a GE EZ81, and an uknown RCA magic eye tube... and also 2 EF86 (oh those tubes look so nice). Thanks in advance for the help! |
#2 |
I guess no one knows about those tubes...
...they even have no filament, so no use as night lamps |
#3 |
Here's a bit more info: http://www.oneillselectronicmuseum.com/page10s.html
The ER21A seems to be ~equal to the GR16. /Hugo |
#4 | ||
Thanks so much! so if I understand well Quote:
Can someone show me how to properly use them? If I understand well, I have to apply a B+ voltage to the anode, and a small voltage to the "ignition electrode" to lit the tube. On the first post there's a link to the pinout, sorry but I'm not able to understand... Thanks in advance! |
#5 |
up!
#6 |
No way to make me a neon lamp?
#7 |
diyAudio Moderator Emeritus
It's all there in the spec sheet.
Apply some voltage (200V or so) through a resistor (maybe start with 100K) between the Anode (a) and Cathode (k) and then another higher value resistor to Trigger (t) and touch the unconnected end of the trigger resistor - If AC I think it should light just for the time you touch, if DC it should stay alight until you disconnect. Be careful.
#8 |
Thank you so much!!!
But I have some doubts: when you say to touch the unconnected end of the trigger resistor, you mean with my finger or with some positive voltage? And by AC or DC you mean the anode voltage or the trigger voltage? And what is the purpose of the pin marked "s"? Sorry to seem so dumb, but I just don't know how those kind of tubes work! I'm not unexperienced in working with tubes, but this is the first time with non audio ones. Thanks anyway! |
#9 | |||
You must have in Italy, small clear screwdrivers with a neon inside for testing mains voltage? This is the same principle. The resistor inside these is normally between 2.2M and 10M ohms. Quote:
What I described is what I would try. It will probably give a result, but it may not. This is sometimes the way to learn. |
#10 |
Thank you so much John!!!!
So you think I could put a 100K 2W resistor from one of the mains leads to the anode, the other mains lead to the cathode, and try to ignite the tube with those methods? Is 220V too much? I will test the thing with an isolation transformer (220V - > 110V) just for safety... I'm so grateful to you!!! |
| Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? | tiefbassuebertr | Solid State | 43 | 22nd January 2012 12:50 PM |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D | jaimegmr | Car Audio | 0 | 5th May 2009 06:39 PM |
| [UK] 2x Pro Audio C12 - 300MB & 2x Pro Audio PST888 Tweeters for Sale | makksus | Swap Meet | 0 | 3rd November 2008 12:12 PM |
| Looking for analog audio circuit designers and audio researchers | cnotley | Everything Else | 1 | 29th September 2008 09:04 PM |
| Page generated in 0.12157 seconds (78.56% PHP - 21.44% MySQL) with 10 queries |
