LM317 Regulator Problem
Old 1st December 2005, 06:46 PM   #1
Bryan is offline Bryan  United States
Default LM317 Regulator Problem
Hey Guys,
For the life of me I can not figure out what is probably a SIMPLE issue.
I have a simlpe voltage regulator circuit for my heaters. It is based on the LM317 regulator. The differemces between my circuit and the one attached are that I have 50uF as the first filter cap, 100uF at the output, and a 220 ohm and 2K pot for the voltage divider, no led and no final 0.1uF at the tubes. There is also a small CM choke before the first filter cap after the bridge.
With no load I can set the output to 12.6, no problems. But when I apply load (ie attach the circuit to the heaters in parallel) the voltage drops to 10 volts with one tube, and 7 volts with two tubes. I can follow this voltage drop all the way to the bridge, which will read 13Vdc after the bridge. I should state the my tranny is 12V/2.5A, and with no load I have about 19Vdc after rectification.
I cant seem to figure out why I am dropping so much voltage?
Thoughts?
Bryan
Dont take life too seriously, you will never get out alive!
Old 1st December 2005, 07:03 PM   #2
Shoog is offline Shoog
Shoog's Avatar
Is your transformer big enough, is the circuit sagging and dropping out of regualtion ??
Shoog
Old 1st December 2005, 07:12 PM   #3
Shouldn't be... The tranny is a 12.6VCT/2.5A. The center tap is not grounded.
The heaters should draw 0.3A each, so TOTAL is only 600mA current. The tranny shouldn't have any problems...
Old 1st December 2005, 07:43 PM   #4
aletheian is offline aletheian  United States
aletheian's Avatar
What's the DCR of the choke? Maybe that combined with a high resistance in the tranny secondary is producing major sag.
Heghlu'meH QaQ jajvam!
Old 1st December 2005, 07:54 PM   #5
ilimzn is offline ilimzn  Croatia
Default Re: LM317 Regulator Problem
Originally posted by Bryan
I have a simlpe voltage regulator circuit for my heaters... The differemces between my circuit and the one attached are that I have 50uF as the first filter cap, 100uF at the output... I cant seem to figure out why I am dropping so much voltage?
Sorry I have to say this but DUH! You substituted a 10000uF filter cap with 50uF, only 200 TIMES smaller - how can this be a proper substitute?! You are getting next to no filtering at the required currents!
Old 1st December 2005, 08:23 PM   #6
So you are saying if I boost up the capacitance before the regulator to 10mF I shouldn't have a problem?
Old 1st December 2005, 08:38 PM   #7
aletheian's Avatar
Now how did I miss THAT statement!? Yes, boost the capacitance and all will be well. That choke right after the rectifier might be forming a little choke input filter too, which will bring the voltage down to about 90%. And if it has a DCR of even only a few ohms, 3 ohms will drop almost 2 volts at 600mA.
Old 1st December 2005, 08:38 PM   #8
Gluca is online now Gluca  Italy
Gluca's Avatar
I made it this way
12VAC, bridge, 10000uF, 3mH, 10000uF, LM317, 10uF. No problem.
Ciao
Gianluca
Old 1st December 2005, 08:43 PM   #9
The choke has an max DCR of 0.39 ohm. I will try adding a large resivoir before the cm choke and see if things improve...
Old 1st December 2005, 09:05 PM   #10
Thanks guys,
4700uF in front of the cm choke and another 1000uF afther the choke cured all problems. Now I just need to heatsink the regulator and all should be fine.
Thanks,
BK
LM317 Regulator ProblemHide this!Advertise here!
TIP50 + LM317 High Voltage Regulator bee696 Tubes / Valves 11 17th January 2010 05:23 PM
12V Regulator problem ifrythings Power Supplies 23 4th November 2005 06:23 PM
Can LM317 be used as GC PS regulator? goering Chip Amps 5 15th September 2004 09:39 PM
LM317 current regulator Bas Horneman Tubes / Valves 22 17th January 2003 11:25 PM
Copyright ©1999-2017 diyAudio
