| diyAudio Sponsor | ||
#111 |
diyAudio Moderator Emeritus
Fortunately the positioning of this particular MOV in this application does not expose it to mains transients. It is merely across a choke.
Quick-start PSU V1.3: |
#112 |
Hi John,
Well, hang one across the primary of the power transforer too! They come in pretty colours. -Chris |
#113 |
We don't get mains bumps. Far from industry, local mains distrubution below ground, and relatively few storms compared with other climes. Poor territory for MOV salesmen....
#114 |
Hi John,
Lucky you! We live in zap central. Lightning and industry. -Chris |
#115 |
All,
Take a look at the level control at the amp's I/P. If a precision stepped attenuator is used as the grid leak resistor of the inverting triode, the low 10 KOhm I/P impedance inhereted from "El Cheapo" can be eliminated. It makes NO sense to put controls that cost as much as the entire amp into a LOW budget project. This project is more about good sound and less about pinching pennies. A high precision resistance is needed in order for the filters at the I/Ps of the 2 channels to have an "identical" turn over frequency.
Eli D. |
#116 |
This post is an utterly shameless bump.
Dec. 26 is Boxing Day. Is that for fisticuffs or for packaging?
Eli D. |
#117 |
Eli,
Just revisiting..... Can you remind me about the 10% tertiaries please: Are each 10% of each anode winding? And... on reflection, does 8K A-A sound in the ballpark? Bearing in mind that the "seen" impedance will be higher due to the cathode feedback. Thanks, |
#118 |
John,
IIRC, each CFB winding is 10%. I'm not sure if 8 KOhms, end to end, is enough. Near Class "B" operation pushes the impedance needed up.
Eli D. |
#119 |
John, did you ever build this?
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Super Sanken Final Stage "Tauro" | Stee | Solid State | 25 | 19th March 2008 08:01 PM |
| help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er | jarthel | Tubes / Valves | 9 | 30th May 2006 07:47 AM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Effect of cross-coupled "local" FB on plate load of previous stage | ray_moth | Tubes / Valves | 23 | 27th April 2005 08:55 AM |
| Page generated in 0.09525 seconds (77.08% PHP - 22.92% MySQL) with 11 queries |
