diyAudio Sponsor
Old 27th November 2005, 07:20 PM   #1
DJNUBZ is online now DJNUBZ  United States
Default newb needs help on simple el84 amp PS
I am planing on building the amp on diy paradise and I have a problem with the PS. For those of you who don't know this amp here is the url
http://diyparadise.com/simpleel84.html
My problem is that I want to build this w/o the choke and I don't know how. I am doing this so I can make this amp for very cheap.
Old 27th November 2005, 08:00 PM   #2
TANSTAAFL! You could use a trafo with a slightly higher rectifier voltage and a CRC, instead of a CLC, filter. Breaking the filter up into CRCRC could help too.
Also, use UF4007 diodes. They cost 15 cents each and are MUCH less noisy than 1N4007s are. The snubber filter between the diodes and the power trafo stays.
Eli D.
Old 27th November 2005, 08:05 PM   #3
Cassiel is online now Cassiel  Greenland
Cassiel's Avatar
Use a resistor, 150 to 300 Ohms (2 Watts) will be fine. Ah, and forget about the cap that bypasses the choke, just put the resistor instead of the choke.
Old 27th November 2005, 09:30 PM   #4
"TANSTAAFL! You could use a trafo with a slightly higher rectifier voltage and a CRC, instead of a CLC, filter. Breaking the filter up into CRCRC could help too."
Could you draw a wiring diagram of this? I can read a diagram but other then that I am a bit lost.
As for the rectifier, I don't mind spending money for good ones. Are there better then UF4007 or should I just use those?
Old 27th November 2005, 10:03 PM   #5
You will do FINE with UF4007s. The snubber filter will kill off the small amount of noise they produce. You could boost performance of the snubber by using a 100 nF. cap., instead of a 10 nF. cap., across the power trafo's secondary. Snubber caps. need to be HIGH WVDC rated, as there are spikes to be dealt with. 1200 PIV Silicon Carbide (SiC) Schottky diodes would be a step up, but they are as expensive as filter chokes. A snubber is not needed if Schottkys are used.
I do schematics by hand and it's hard for me to post them. Perhaps another "denizen" will provide a CRCRC filter drawing.
Eli D.
Old 27th November 2005, 10:13 PM   #6
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 28th November 2005, 08:19 PM   #7
I am going to stick with CRC for now, I think. Should I still use 100uF caps for this or go larger? If I were to go with a CRCRC what size resistors would I use and what caps?
What is the main bennifit from switching from a CRC to a CRCRC?
On the schottky's I have looked but I don't see any that cost as much as the $30 choke. Am I looking at the wrong thing on mouser?
Old 29th November 2005, 01:38 AM   #8
The PIV rating of the Schottky diodes Mouser carries is WAY too low for B+ PSU duty. Cree 1200 PIV SiC parts are in order and they cost over $10 each. Parts Connexion carries Cree SiC Schottky diodes.
Parts Connexion
BTW, if the B+ supply was bridge rectified, lower cost 600 PIV parts could be used. 4X 600 PIV parts cost less than 2X 1200 PIV parts and there are multiple manufacturers.
Eli D.
Old 29th November 2005, 03:09 AM   #9
I guess I'll stick with the cheap ones.
What about the resistors and caps in a CRCRC?
Old 29th November 2005, 05:35 PM   #10
For the PS caps will these work?
http://www.partsexpress.com/pe/pshow...umber=020-1458
or am I looking at the wrong kind of cap?
Simple EL84 amp... Skorpio Tubes / Valves 11 3rd January 2009 08:25 PM
Everything but the subs (simple newb question) bigron Car Audio 10 19th December 2007 07:09 AM
Yeo's Simple EL84 with a twist sorenj07 Tubes / Valves 19 18th October 2006 09:48 PM
Simple EL84 Mas Penk Tubes / Valves 25 17th August 2006 01:55 AM
anyone tried the diy paradise simple el84 pp RockysDad Tubes / Valves 6 11th April 2005 04:19 AM
Page generated in 0.09414 seconds (85.62% PHP - 14.38% MySQL) with 11 queries
