diyAudio Sponsor
Old 26th November 2005, 04:20 PM   #1
Default Help for newbie building Toccata preamp
Everyone,
I building Thorsten's Toccata preamp (http://www.fortunecity.com/rivendell...a/Toccata.html) and I have a newbie question about the power supply (schematic attached below). I've breadboarded the 9V filament supply and in a no-load situation I am getting 14.5 VDC across the outputs after the caps as opoosed to the 9V on the schematic. The 9-0-9 transformer is putting out about 10-0-10 so some of the over-voltage comes from that. I've checked the cap ciruit about a hundred times so I don't understand what could be wrong. This isn't my first project (I build a JELabs 300B) but admitedly I am very inexperienced about circuit theroy. What am I doing wrong?
Jonathan
Old 26th November 2005, 06:36 PM   #2
You will get far less voltage under load, most likely. Filaments draw a lot of current.
-j
Old 26th November 2005, 06:41 PM   #3
moamps is offline moamps  Croatia
It's just fine. The caps are charged to the peak voltage; Vp=1.4*Vrms.
The voltage will drop when you load power supply with the current sources and the filaments.
Milan
Old 26th November 2005, 07:33 PM   #4
Thank you so much. I will sleep much better tonight.
Jonathan
Newbie building d3A DRD 300B stefanolo Tubes / Valves 8 3rd February 2007 02:51 PM
Best Toccata & Fugue in D Minor? ReidK Music 11 19th December 2006 11:21 AM
Toccata Phono Preamp Algar_emi Tubes / Valves 19 11th November 2006 01:48 AM
Newbie building JFET Zen v8 summilux Pass Labs 12 26th January 2006 09:40 PM
Newbie at this speaker building! Please help! JiggaD369 Multi-Way 11 23rd June 2005 12:38 AM
Page generated in 0.08656 seconds (72.46% PHP - 27.54% MySQL) with 11 queries
