diyAudio Moderator Emeritus
Finally completed my tri-channel amp...suitably called frontrow..rugby fans will now what I mean..if not still a meaningfull name puts you on the frontrow of a cinema/concert ;-)
Have listened for 2 evenings now and it ....well... it makes me a proud and happy man.. For details http://home.zonnet.nl/horneman/6c41c.htm |
#3 |
Wow! nice work...
Love that wood look, really makes it look old-world... What are the ratings on those triodes and where do you get them? |
#4 |
With a name like frontrow..it had to be a Kiwi to reply first! :-)
I'm originally a South African, now living in Holland, hence my love of rugby... Back to business. Here are a couple of links.. http://www.tubes.ru/techinfo/AmateurRadio/6c41c-b.html http://www.next-power.net/next-tube/Data/6C41C.xls http://www.jogis-roehrenbude.de/Russian/6C41C.htm http://www.mclink.it/com/audiomatica/tubes/6c41.htm and you can get them from KWTUBES on eBay or directly from http://kwtubes.s5.com/ in Lithuania..From Gintaras Sakenas..great to do business with.. Great contact and speedy handling of order..only drawback (IMHO) is bidpay since there is no paypal in Lithuania yet. But since you are a Kiwi and first to reply, I'll send you a pair if you mail me your adres... |
#5 |
looks pretty neat
![]() the woodwork is great. sound good?? I had a russian DHT coming a while back, but it broke in the mail ![]() ( a couple 807's made it though, ill have to give them a shot.. probably for guitar though). I've got some 6159's (25v heater version of the 6146 transmitting tube). I think I will try them in AB, if I ever get the iron for it.. nice work! |
#6 |
Thanks for the compliments...
What DHT did you get? that broke...I have a couple of russian GU 13 that I want to use in a future ..future project... a guitar amp is also a project that I want to do..just for fun...i don't play guitar ...but what the hell The woodwork is pretty plain..2 boxes with a top...that has a profile routed in...but it turned out quite nice if I may say so myself.. It sounds very good...tremendous detail..nice mid's and high..bass is not super..but can be improved if I bypass the cathode..even then it is not super but that is also limited by my speakers ofcourse (mission761) but i find that that muddles up the mids a little.(cathode bypass that is) .so i've actually left it unbypassed.. ...it's the best amp i've ever had/made....I still can't believe I actually built it..and it works? Hum is only audible if I put my ear to within 1meter of a speaker..It worked right "out of the box" so to speak and I had to do no debugging to get it this quiet.. it's choke input and I did not know that choke input could be so quiet..i always thought that it would be noisier... Good luck with the 6146 project... |
#7 |
diyAudio Senior Member
Hi South Africa,
Congrats on your amplifier. Time to debug the residual hum now? Subjectively cathode bypass caps do slow down transient attacks and dynamics don't they? Had a look at your site as well,it's cute too! Rgds,
Frank |
#8 |
Hi Frank,
Thanks for the compliment on the website and amp... What Hum????? ;-) Last night put up in a 15uF Audyn cap as bypass..so if I understand correctly I'll have everything above around 20Hz fed back..but the treble sounded horrible that way...so I added a 0,056 russian teflon cap...voila...a lot better. Sounds pretty good and I will keep it like this for a while before I start tuning it.. Regards, Bas |
#9 | |
Hi Bas,
Since I have no idea about the efficiency of the Mission 761 I was just wondering if it could still be improved upon. If it doesn't bother you the better. See you,
Frank |
#10 |
Hi Frank,
I know..but I was just trying to be funny.. The hum is so little that it does not bother me..but I might try in futere one or two things..I am quite limited because of the space I have inside the amp... Cheers, Bas |
| 6C41C in OTL? | Alastair E | Tubes / Valves | 1 | 8th January 2007 11:36 PM |
| 6S41S (6C41C) Amplifier | zogu | Tubes / Valves | 5 | 4th November 2006 11:40 PM |
| Interested in 6C41C SE? | coffin | Swap Meet | 14 | 29th October 2005 07:23 AM |
| PSE with 6C41C | AKSA | Tubes / Valves | 9 | 20th February 2004 12:39 PM |
| 6C41C tubes | WALTER BURKHARD | Swap Meet | 0 | 27th June 2003 02:14 PM |
