| diyAudio Sponsor | ||
Hi
Currently i have a MV55 and PV10L bought together from the importer and problem occurs when the biasing lights is flicking and the light emmited out by vacuum tube filaments is not constant, the spearker also give out popping sound. I switched off the set and on it back again and the set play well but after two songs later the same problems come back again. I tried a few times and the earth leakage circuit breaker started to trip. I isolated the power ampand preamp and power them up separately, the power amp biasing lights does not flicker anymore. As for the preamp, it seems ok and i let it on for 15 mins..when smoke started to come out from the Transformer. The transfomer is a Magnetek 783P2 and i cant find it in my country. Since there is no voltage indication in the transformer, i could not find other transformer to replace. Is there any body there to help me to advise what is the voltage require and what other brand of transformer i can use..thanks! |
#2 |
Magnetic 783P2 can be replaced.
you have 110v or 240V in singapore. |
#3 |
Hi, thanks for your reply, we have 240VAC in Singapore.
#4 |
Avantgarde,
Did you manage to find out the output voltage of the transformer? I am planning to diy a pv10a but don't know the voltage neither. If you did, please also let me know. |
#5 |
Email magnetek at info@magnetek.it . They can send you a datasheet, and tell you where you might find one in .sg or .hk.
Keep in mind that the transformer smoked for a reason.
-e |
#6 |
Hi.. do you have the PCB layout of the PV10AL?? Thanks
| about hip4080a,burned | freebird888 | Class D | 9 | 23rd May 2009 12:27 PM |
| Burned Up Transformer in HiFi 6p3p Tube Amplifier | dmitch31 | Tubes / Valves | 3 | 26th February 2009 03:40 AM |
| mc100b burned up | DOWL | Tubes / Valves | 0 | 6th July 2008 04:14 AM |
| Help - just burned a ZV4 channel | miguel2 | Pass Labs | 9 | 24th October 2002 06:05 PM |
| Page generated in 0.09195 seconds (73.52% PHP - 26.48% MySQL) with 10 queries |
