diyAudio Sponsor
Old 23rd November 2005, 02:14 PM   #1
Default Loaded Question
How does one calculate the load an input tube is working into when the next stage is a power tube, cap coupled?
How about the Aikido input tube, its loaded by the other half of the tube?
thanks,
dr._sleep
Old 23rd November 2005, 02:22 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Loaded Question
thanks,
dr._sleep
I assume you mean AC load (the DC load is different). Is the power tube into grid current? That is a load for the driver (or prestage). If not, you have - for AC - everything in parallel to make up the load: pre tube anode load, next stage grid resistor, whatever. Remember, for this calculation, for AC, the B+ and ground are the same, and the cap can be seen as a short. Any impedances to either B+ or ground, on either side of the cap, are in parallel.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 23rd November 2005, 09:23 PM   #3
Miles Prower's Avatar
(See attached)
The load of the next stage grid is composted of the grid resistor in parallel with the specified capacitances: the grid-to-cathode capacitance, plus the Miller capacitance from: C(miller)= Cgp(1 + Av), plus the inevitable stray capacitance. The latter can be guesstimated as 30pF (you can't make it much less, but you can make it considerably more with poor construction techniques).
For the low frequency end of the audio range, the tube capacitances can be ignored. At the high frequency range, these become important and it is necessary for your driver to be able to supply those additional currents if you are to avoid slew rate distortion. If you don't go into grid current, then just about any medium u tube operated a sane load line should provide that current to any pentode or beam tetrode operated as pentodes/tetrodes. (High u tubes may not have enough moxie to drive a power tube directly, so you can use a cathode follower for adequate power grid drive.) This can possibly become problematic if triodes are used, as power triodes typically have larger Miller capacitances.
Of course, classes that require grid current have the additional load represented by the resulting grid current. In those cases, you probably need xfmr coupling or something like a power MOSFET to supply the necessary grid power. And that's a whole 'nother story.
There are no foxes in atheistholes
www.dolphin-hsl.com
New member with a question about horn loaded compression driver-type speakers... munkittrick Car Audio 15 27th May 2009 12:49 PM
Loaded question: what is the best full range driver? gnugear Full Range 16 11th March 2008 10:24 PM
A question about back loaded horn efficiency BHD Full Range 13 13th December 2006 07:15 PM
PA horn-loaded midrange cabs question Bull Multi-Way 3 4th September 2005 09:55 AM
rear loaded horn question zobsky Multi-Way 5 21st September 2004 08:13 PM
Page generated in 0.07578 seconds (71.15% PHP - 28.85% MySQL) with 11 queries
