| diyAudio Sponsor | ||
#781 | |
Banned
#782 |
Cypher,
Rk is the same regardless of load type as far as I know. Your calculations look OK to me.
Thanx! |
#783 | |
diyAudio Senior Member
Cheers and see at that other thread,
Frank |
#784 |
Here are my thoughts on 12B4 preamp. Does the picture look right?
#785 |
You wouldn't be the first person that Bruce pissed off! There have been many others too. It's been a while since I've trolled this thread so I unfortunately can't say if there was a toobe rectification circuit posted or not. Another possibility you can consider and one to get even with Bruce is to get one of the Chinese grounded grid kits. I've built one and for the money it's not only quite decent but it will teach you gobs about audio and doing mods as it is very mod-able. Out of the box it sounds decent with the right toobes. I don't normally recommend ANY Chineese stuff to anyone however I've always felt that Bruce could do more good by showing a little more humbleness towards those that support him.
Getting back to the 12B4, there are SO MANY ways to go with the darn thing that it would be fairly easy to fill a book. If you really want to proceed down the 12B4 path you might want to haunt EBay for a used variable high voltage DC supply. I only paid 30 bucks for my Eico unit. It also helps to have a smaller say 0 to 24 vdc bench supply for filaments. With all the experimenting you'll be doing it is really the best route. Mark Mark |
#786 | |
Amplifiers and select "My Favorite Line Stage Amp" to see my recommended solution for this problem. You will note that the regulator is isolated through a small buffer resistor, and that final filtering for the 12B4 is done on the load side of the buffer. For those of you who have been waiting for my 12B4 kit to come--it is finally here! This posted design is the final version, and I am doing a test build with one of the forum members for the first kit. I'll be placing in up on Old Stock Audio for sale as a complete kit with custom case and options once the first 'kit' test is completed. You can contact me if you are interested.
"Make me to know the end of my days" King David |
#787 |
You should have sent me the trial kit... I'd have had it built on a nice chassis in a couple of days and you'd already be selling them. Count me in for one of the kits. I once built a 15" Heathkit color tv over a three day weekend... And it worked fine on first power up...
Mark |
#788 |
2x60H is overkill. At that Rp (about 1k) one could go just fine with say 40H. No need to add excess capacitance (from the chokes) and limit your upper bandwidth. Same goes for the extra resistance(thus higher B+ required). With just one 60H choke u get F3 = 3Hz @ Rp = 1k.
For the record 40H choke gives F3=4Hz @ Rp = 1k. Venci. |
#789 | |
BTW these chokes are custom made for me in Hong Kong and even in serial mode have an upper frequency cutoff way above 100KHz.
#790 | |
| Page generated in 0.13750 seconds (76.66% PHP - 23.34% MySQL) with 11 queries |
