Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... - Page 52 - diyAudio
Old 5th October 2006, 03:26 PM   #511
zobsky is offline zobsky  India
zobsky's Avatar
Originally posted by Wavebourn
Unlike Zeners they need a higher voltage to fire up, after that they drop voltage down to a regulated level. Slightly different resistors across them is the way to fire them up one by one and make resulting fire-up voltage less, if you connect them in series.
Could you post a rough schematic? I wasn't aware that VR tubes needed resistors across them. I do know that they need a resistor above them eg.
http://www.tpub.com/content/neets/14.../14178_150.htm
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 5th October 2006, 03:33 PM   #512
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Connect 2 gas tubes in series. Slowly rize voltage on them, of course through a current limiting resistor. Now connect pair of high ohm different bleeding resistors across them and compare. You may use a variac in the primary of your PT to check what voltage is needed to fire them up if you don't have a laboratory source of regulated voltage.
The Devil is not so terrible as his math model is!
Old 6th October 2006, 12:22 AM   #513
Or just ask Zen Mod to do the quick calculations for you .
Mark
Old 28th October 2006, 01:05 PM   #514
Alright, I will ask Zen Mod or anybody who can simulate this:
I bought a transformer just for this project to run those OO3 gas regulation tubes. Do I need a choke or filter arrangement for this transformer to run those tubes correctly???
Transformer: www.edcorusa.com Model: XPWR106
115V 60Hz. 275-0-275
125mA 6.3V, 4A
Primary Voltage:
115VAC
Primary Frequency:
60Hz
First Secondary winding:
275-0-275VAC, 125mA
Second Secondary Winding:
6.3VAC, 4A
http://www.edcorusa.com/classx/power/xpwr/Xpwr106.htm
Old 28th October 2006, 08:17 PM   #515
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
125mA 6.3V, 4A
Primary Voltage:
115VAC
Primary Frequency:
60Hz
275-0-275VAC, 125mA
6.3VAC, 4A
you bought it before you know it's good or not?
which schematic?
like Mark's -with R on anode?
preliminary - that xformer is on the edge here..... if I presume that you want R loaded stage,with two OD stacked per channel.....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th October 2006, 09:08 PM   #516
which schematic?
Same... identical as Mark's.
Mark... Mark my word on that!
Old 28th October 2006, 10:09 PM   #517
Zen Mod's Avatar
in that case
xformer
then two schotkys (even from PC supply) as full wave rectifier ,common for both channels
then muuuucho of capacity
then same schmtc as for Mark's (one I drew it here..........http://www.diyaudio.com/forums/attac...amp=1147048038
mebbe just slightly smaller resistor in front of gass toobz,just because your (Lucky's ) voltages will be smaller than 400V before gas stabz
anyway-I can bet that xformer will be warmmmmmmmmmmmmm
Mark-did you tried your super reg variant?
Old 29th October 2006, 03:02 AM   #518
Not yet... time factor, time is a 4 letter word. Working on KSA-100 and then this 12B4 line stage or he is going to come to hunt me down!
Mark
Old 29th October 2006, 10:53 PM   #519
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I decided to put my 12B4A preamp in a different chassis-
Zen Mod, ugly enough for you?
Old 29th October 2006, 10:55 PM   #520
Zen Mod's Avatar
ugly!
Copyright 1999-2017 diyAudio
